loud squeal full throttle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Apr 6, 2013.
  1. Apr 6, 2013 at 11:35 AM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    my 2006 Tacoma v6 with 70k on it is making a loud squeal under full throttle. It only does it on the road,not in park or neutral. Any thoughts? It started suddenly the other day,and has never happened before.
  2. Apr 6, 2013 at 12:09 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
  3. Apr 6, 2013 at 9:09 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Or fan clutch, but replace the belt first and see if squeal goes away.
  4. Apr 7, 2013 at 12:10 AM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
    Full throttle in park or neutral is one of the worst things you can do to your engine other than running it without oil. :confused:
  5. Apr 7, 2013 at 5:43 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Could be seagulls being sucked into the intake. :notsure:
  6. Apr 14, 2013 at 6:46 PM
    USNavyTaco
    Goose Creek SC
    Im not fully crushing the pedal in neutral, just a bit of gas to see if it squeeks. AND UPDATE!. Its not the belt, or the pully. Its coming from the rear end somewhere Im wondering if this is related to the squeek I had in reverse a few weeks back,then went away. But anyhow, this full throttle squeek is here to stay, and as I said, its coming from the rear end. Im starting to think Im feeling more vibrations than usual too, but that might just be me being more attentive now. I just had a failed u joint replaced last summer, but as I recall, my entire rearview mirror was shaking, and its not this time. So, any thoughts?
  7. Apr 14, 2013 at 6:49 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    check the oil in your diff?
  8. Apr 14, 2013 at 6:57 PM
    USNavyTaco
    Goose Creek SC
    I just had the rear diff oil replaced at a toyota dealer last year when I hit 50k on the truck. And it gave me no problems since then, and I park it in the same spot everyday, and theres nothing on the ground, so unless its literally evaporating out of the diff, the fluid level is fine (I would think), but any other thoughts?
  9. Apr 15, 2013 at 5:42 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Either a bad u joint, or center support bearing. A diy diagnosis is to jack up the rear and set on jack stands, chock the front wheels(very important), start the vehicle, disengage all the traction control features, put the truck in drive(best to use 2 people), have someone in the drivers seat to hit the gas while you look under the truck to see whats squeeling, careful not to get too close to moving parts and also careful that the truck does not come off the jack stands when your helper steps on the gas pedal. This is dangerous, so if you don't feel comfortable doing this, then don't do it. Also, with the truck on the ground, you can shake the drive shaft at the u joints to see if they have any movement to diagnose a bad u joint. Good luck, and be careful.
  10. Apr 15, 2013 at 6:55 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    This reminds me of the old joke which goes something like this. Man walks into the doctor's office and says, "Doc, it hurts when I do this. Doctor responds with "Well, then don't do that." In this case, it's not a race car. Don't run it under full throttle. Anyway, going to be hard to figure out since it's happening only on the road, not when stopped. Obviously in the drive-line. You're the only one here who has heard the squeal in your truck. What moving part could squeal like that?
  11. Apr 15, 2013 at 7:21 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Possibly the carrier bearing going bad? Get under the truck, and see if there's excessive play in the CB. Just grab the driveshaft near the CB, and move it in all directions. I believe if there's more than a 1/4" of movement, the bearing is going bad. Could be the cause of the squeal.
  12. Sep 5, 2013 at 5:58 PM
    rufuss11
    rufuss11 Well-Known Member
    CA
    2010 Double cab Offroad
    5100's set at 1.75, aero turbine
    Just yesterday I noticed my 2010 DC with 55,000 miles 4x4 TRD making a squeal sound similar to this one. I started out with a sort of clicking sound and as the day went on it started to squeal. It happens when accelerating. It started out as just a clicking or ticking and then with more thoatal it turns into a squealing sound. any more suggestions?
  13. Sep 5, 2013 at 5:59 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    My first thought.
  14. Sep 6, 2013 at 8:56 AM
    rufuss11
    CA
    If it was a belt wouldn't it squeal while in park and nutural? It only does it while driving. There is also a clicking or cracking sort of sound.
  15. Sep 6, 2013 at 2:03 PM
    rufuss11
    CA
    So after reading more posts. I feel it is my joints. I have read post of people replacing them and some jack the back of the truck up to prevent the loss of ATF, is this necessary? How much fluid will I loss if I don't jack it up considering I only have the stock bottle jack?
