Loud squeal, knock then dead battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06tacomatrd537, May 18, 2017.
  1. May 18, 2017 at 5:18 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I'm not sure, but some people are naturally hopeful that bad things will go away.
    Possibly , but that is extreme, and he wouldn't have been able to turn over the engine with a jump.
    EDIT: Now that I've had a bit of go juice this morning, I'm afraid that you may be right. Here is hoping that it is something far less expensive.
    True, but pointless if the fan belt or other accessory is in pieces. Besides the OP may not have a scanner in his arsenal yet.
  2. May 18, 2017 at 6:39 AM
    06tacomatrd537
    06tacomatrd537 [OP] Member
    Les
    2006 trd 4wd
    None
    I did that because it had not been cranked in 3 years. What else could I have done?:duel:
  3. May 18, 2017 at 6:53 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Well that changes things a bit. What was wrong with it to cause it not to be started in three years?
  4. May 18, 2017 at 6:53 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Ah, well that is important info not in your original post!
    So truck sat for three years without use and now you changed fluids (which ones?) and are having this problem. Is that a correct summary?
    Gunshot-6A and Plain Jane Taco like this.
  5. May 18, 2017 at 6:55 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    maybe you drained the tranny and over filled the engine
    06tacomatrd537[OP] likes this.
  6. May 18, 2017 at 7:29 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Yes sat for three years. I changed oil and antifreeze.
  7. May 18, 2017 at 7:31 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Same symptoms. The guy I bought it from said it made a loud noise, quit and wouldn't do anything.
  8. May 18, 2017 at 7:32 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Temp was fine...perfect
  9. May 18, 2017 at 7:33 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    If it was seized it wouldn't crank right?
  10. May 18, 2017 at 7:36 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    I paid a few hundred for it so y'all don't beat me up too bad
  11. May 18, 2017 at 8:00 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    My nickel is on connecting rod bearing(s) seizing.
    Engine cools down, bearing shrinks in journal. Start it up - knock knock knock, gets too hot (maybe from a clogged oil galley), then SHREIK, seizes and motor stops.
  12. May 18, 2017 at 8:01 AM
    80schild
    Chad
    Flori-Bama
    Is this a 4cyl or V6?
  13. May 18, 2017 at 8:04 AM
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Can I add a video from my phone on here?
  14. May 18, 2017 at 8:21 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    You need to post it up to YouTube or the like and then use the embedded MEDIA button to add the URL.
  15. May 18, 2017 at 8:23 AM
    #35
    Dragons Taco
    Derek
    Cary/Raleigh NC
    OK, so we don't know the history. For all you know the water pump is bad, or he ran it with no oil and the engine is foobar.
    You were just the one to get to witness it's last breath.
    Where are you located?
  16. May 18, 2017 at 8:31 AM
    #36
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Philadelphia ms
  17. May 18, 2017 at 8:31 AM
    #37
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    Its still running
  18. May 18, 2017 at 10:40 AM
    #38
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    6
  19. May 18, 2017 at 10:43 AM
    #39
    06tacomatrd537
    Les
    2006 trd 4wd
    None
    I was going to fix it but I think I'll sell it. It was vehicle #6 so it's got to go. I work on old stuff like my 73 bronco or 67 mustang. This new stuff is for the birds. Thanks for all the insight
  20. May 18, 2017 at 10:46 AM
    #40
    06tacomatrd537
    Les
    2006 trd 4wd
    None
