Loud squealing, please HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by mblkh2o, Feb 23, 2025.
  1. Feb 23, 2025 at 1:23 PM
    mblkh2o
    mblkh2o [OP] Well-Known Member
    Manny
    Chandler, AZ
    2002 Black Tacoma TRD Crew Cab
    2.5 inch Bilstein 5100 lift and 3 leaf progressive springs w/Pro Comp 69 series wheels and BFGoodrich K/O2 265/75R16's
    Hi everyone,
    I have a 02 tacoma 3.4l v6, I parked the truck and then after about a couple minutes it started squealing really loud and bad, i could smell something burning and then I looked under the hood, I couldn't see anything and then I tried again and I could feel it and hear it through the ignition when I was cranking it, it was going to squeal again and sure enough it did, I quickly looked to see what was wrong and I noticed the fan clutch wasn't spinning and one more thing. Before this all happened I could hear that something spinning like it was loose but I couldn't pinpoint the noise and now it won't stop squealing, I havent tried driving it yet. Please any suggestions would help, thanks guys
  2. Feb 23, 2025 at 1:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Take the drive belt off and start spinning thing by hand.
    TheWildMan and MadNachos like this.
  3. Feb 23, 2025 at 1:36 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Frozen idler or something else that is forcing the belt to slip is the issue. Remove the belts and see what doesn't want to turn by hand.
    TheWildMan likes this.
  4. Feb 23, 2025 at 5:56 PM
    MadNachos
    Interesting related story. My son has an old Chevy van and on a recent trip the alternator seized up to the point where it stalled the engine. Never seen that one before. But similar issue.
  5. Feb 23, 2025 at 6:08 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    it may be an old belt with no grip.
  6. Feb 23, 2025 at 7:45 PM
    mblkh2o
    Manny
    Chandler, AZ
    When the truck was running i could hear like something was loose squeaky like it needed lube and then the loud squealing started and stopped the fan clutch as well, I'll have to try that
  7. Feb 23, 2025 at 7:47 PM
    mblkh2o
    Manny
    Chandler, AZ
    I'm also going to do that hopefully this week and they're all oem belts too, maybe 20k-25k miles old
    MadNachos[QUOTED] likes this.
  8. Feb 23, 2025 at 8:02 PM
    MadNachos
    You have the V6 so it could be an idler on the cam belt, that would be a worry, but hopefully not. Worth keeping in mind.
