Loud Squeeking Sound From Front End
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishWolf, Oct 16, 2022.
  1. Oct 16, 2022 at 10:30 PM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    I have a loud squeek coming from lower ball joint area from left front end of my truck, is that normal when these go out or maybe something else, just looking at common causes to look at, guy at Les Schwab seems to think its lower ball joints but Ive never had much faith in their company in general, plan on taking it to my local Toyota dealer for a second opinion, and will have them do the work with Toyota parts if thats the case, I do have Total Chaos upper control arms which can also make similar sounds when in need of lube but Ive already done that, any input would be appreciated
  2. Oct 16, 2022 at 10:55 PM
    tcjacado
    tcjacado Well-Known Member
    How old are the ball joints on upper and lower control arms?. I would recommend grease finally 4 ball jointd, if can through the zerk fittings if you have them if not then replace them (upper and lower ball joints) on each side.
  3. Oct 16, 2022 at 11:19 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Im not sure how old they are, Im the third owner of the truck, do they have grease zerk points?
  4. Oct 16, 2022 at 11:26 PM
    tcjacado
  5. Oct 16, 2022 at 11:31 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Ill look again but I didnt see any for the ball joints
    tcjacado likes this.
  6. Oct 17, 2022 at 12:02 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I never seen any on the OEM control arms.
    Some after market arms do.
    The driveshaft may or may not. Most all the 4x4 trucks have them on the front and rear.
    Some late model 2nd Gens didn’t have them on the rear. You just have to look and see.
  7. Oct 17, 2022 at 12:25 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    One of the ball joints is probably internally rusted. Even if grease is in it, it is defective.
    This can happen and has on many makes and models, but is somewhat rare as they fail in other ways long before they exhibit these sort of annoying issues.
  8. Oct 17, 2022 at 12:02 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    I live in a high humidy area, so maybe more prone to rust/squeeks
  9. Oct 17, 2022 at 12:10 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Ive seen some people talk about injecting grease into boot and even add zerk fittings to existing ball joints
