Loud start up after an oil change
Discussion in 'Technical Chat' started by TacomaZL, Jul 11, 2016.
  1. Jul 11, 2016 at 1:55 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    So this is more of a general question, but still tacoma related. I have worked on 4 different vehicles in my life and changed oil in all of them. In my Tacoma and an Explorer I would change the oil, start it up, and everything was normal.
    In the Mazda 3 and Honda Accord i have worked on, both make a loud noise at start up after an oil change and then it would stop after about 2-3 seconds and on subsequent start ups never repeated the sound until the next change.
    In ALL these vehicles I have never filled the filter with oil beforehand.
    What is causing this? Am I damaging something? I have always wondered what's wrong.
    Rambo MARINE Recon likes this.
  2. Jul 11, 2016 at 10:02 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    The engine is essentially running without oil for those seconds. It takes time to fill the empty oil filter before the rest of the engine receives any oil after a change. There isn't much you can do about it because most newish vehicles have an oil filter that is is oriented so that you can not pre-fill the filter with oil.
  3. Jul 12, 2016 at 6:31 AM
    TacomaZL
    Illinois
    So if possible I should prefill?
  4. Jul 12, 2016 at 7:24 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Yes but that only works if the filter sits vertically. Otherwise the oil dumps out when you try to spin it on.
    Rambo MARINE Recon and Markcal like this.
  5. Jul 12, 2016 at 7:26 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Definitely.
  6. Jul 12, 2016 at 7:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Testing memory here..........
    Thinking the Mazda & Honda are OHC with hydraulic lash adjusters (HLAs)?
    The Tacoma is OHC, but with solid lash adjusters in bucket?
    The Explorer is cam in block with hydraulic lifters?
    If that's right, the HLAs have a tendency to drain faster. The start up noise you hear is the valves till the HLAs pump up again. It's unlikley a prefill of the filter would stop that (but it might reduce it) and it's also unlikely that any damage is being caused.
  7. Jul 12, 2016 at 2:34 PM
    TacomaZL
    Illinois
    Thank Bill, I knew there was some sort of correlation. I think I may start pre-filling in all vehicles that I work on now (I still work on the Mazda, OBVIOUSLY the Tacoma, and Accord). I always warn the owners of the other two vehicles that there will be a loud, momentary noise at start up, but have always felt that is very "unprofessional". I take great pride in doing the best I can when working on a vehicle, regardless of whether I own it or not.
    Guess I'm gonna be a prefiller from now on. Thanks guys, any more input from others is still welcome...I enjoy many different viewpoints.
  8. Jul 16, 2016 at 6:40 PM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Try 8 ounces of TufOil Additive at every oil change, coats and clings to bare metal with PTFE and Synthetic oil !Usining it since my first oil change at 3,000 miles when new and still do at over 60,000 miles 4 years later,,no noise, better MPG, cooler operation in summer heat!Order on Amazon or EBay.SAM_0359.jpg
