Loud thunk when trying to engage 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnm2491, Feb 22, 2021.
  1. Feb 23, 2021 at 6:34 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Question: Where do you live? This sure as hell doesn't apply to where i live.
  2. Feb 23, 2021 at 9:22 AM
    MonsterGuy
    MonsterGuy Well-Known Member
    Hill Country, Texas
    2009 DCLB TRD Sport 4x4
    My truck also does "thunking" when I flip it into 4 high sometimes. I think it's from the front drive line and tires slipping maybe, it just makes a loud noise as it suddenly engages.
  3. Feb 23, 2021 at 9:51 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Ditto. I guess I've been doing it wrong for 30 years. 40MPH on JUST snow (not ice) is fine and 4WD can help. Ice is a totally different thing and not the subject of this thread (presumably), because if he was going 40MPH on ICE, he wouldn't have to worry about the clunk because before long his truck will be in a ditch totaled.
  4. Feb 23, 2021 at 9:57 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I couldn't leave the house for 5 months if it wasn't safe to drive in 4HI over 20 mph. Holy balls. Snowy, icy roads are meant for 4HI.
  5. Feb 23, 2021 at 2:49 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    That isn't true at all.
    LooneytuneSR5, reg0928 and jproffer like this.
  6. Feb 23, 2021 at 8:55 PM
    757.Taco
    757.Taco Well-Known Member
    Nick
    Weatherford, Texas
    2009 4x4 Manual RC
    Mine only clunks after disengaging 4hi at a standstill and then accelerating. Disengaging while moving with gas out and clutch in seems to do the trick.
  7. Feb 23, 2021 at 9:36 PM
    evoedgar23
    evoedgar23 Edgar
    Plano, TX
    2012 Reg Cab Tacoma 4x4
    I noticed my 12’ clunked a few times during the Texas storms but largely in part to my slow speeds and turning. Not very good to go full lock on 4hi :oops:
  8. Mar 2, 2021 at 4:47 AM
    Johnm2491
    Johnm2491 [OP] Well-Known Member
    2024 TRD Off Road DCSB
    Frigg-off Barb
    Update: took it to an off-road shop here in Utah and found the vacuum line was unplugged on the actuator and all is full of dirt so getting it replaced should do the trick they say
    RHHousehold likes this.
  9. Apr 15, 2022 at 7:44 AM
    jmf78
    jmf78 New Member
    2011 Tacoma Double Cab TRD Offroad
    I got the loud clunk this past January. Great timing for NWPA weather being in the snow belt. Was at the end of my driveway and needed 4WD to get out safely as I hadn't a chance to plow. Loud clunk, got out of the driveway and immediately took it out of 4WD. Started moving slowly down the road and wanted to see what it'd do if I went back into 4WD. Another loud clunk and then some lighter clunks. Tested a few times after and the same thing. Also, 4WD would not engage. Took the truck to my mechanic, he looked at it and ended up calling the local Toyota dealership. They told him it was the Transfer Case Actuator and that it was about $1300 just for the part.
    I've since been doing some searching and it appears I can get the part for $150-$200 and appears to be fairly simple to replace. I'm just wondering if anyone here agrees with the diagnosis? I'm looking to trade the truck in and would like to get this fixed first.
    Thank you.
  10. Apr 15, 2022 at 7:05 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    To those who are having 4WD HI and/or LO engage / disengage issues: it can save considerable money & wasted effort if you take the time needed to understand how the moderately-complex part-time 4WD system in 2nd gen tacos works. It's pretty common for dealerships & mechanics to misdiagnose 4WD. The best way to reduce the risk of them doing so is for you to understand in detail how all the 4WD parts and systems interact. This thread about 2nd gen 4WD is excellent: https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    If you don't already understand what 4WD "binding" or "wind-up" is, explainer videos like this one will go a long way towards helping you build a fundamental understanding of why an otherwise-normally-functioning part-time 4WD system may be difficult (or even impossible) to disengage in certain circumstances. (Note: the video calls it "transmission windup" but it's actually "transfer case windup".):
    https://www.youtube.com/watch?v=1EHcrjIlkHk
    As to safe speeds for engaging 4HI: I routinely exercise my 4HI by engaging and disengaging it while going in a straight line (very important) on flat, dry asphalt at freeway speeds -- i.e. in-gear, cruising at 60MPH, with light accelerator (i.e. at the typical 2.2K engine rpm for 60MPH in 6th gear in a manual-trans taco with stock gearing and 265/70R16 tires.) I have never experienced any clunks, jolts, bangs, steering disturbances, etc. when exercising 4HI in this manner. When doing this on dry pavement it is important to disengage 4HI while still on a straight section of road. (Before any significant curves / turns are needed.)
    Note, I would never try to engage 4HI at high speed if there is significant torque load on the drivetrain, i.e. accelerating up a steep incline, towing a heavy trailer, etc.
    I have experienced 4HI disengage clunk sometimes at low speeds, if there is bind-up in the transfer case due to my having recently made unrelieved turns. (Unrelieved = tires did not chirp or scuff to release drivetrain tension induced by differing wheel speeds.) This is probably the most common source of 4WD clunk.
    I suspect, but don't know for sure, that there may also be 4WD "clunks" related to the front propeller shaft slip joint (aka spline joint): If 4WD doesn't get used regularly I wonder if it's possible that this joint gets sticky and/or dry, possibly causing it to go "clunk" because the joint either doesn't have enough grease, or what grease is there isn't evenly/fully distributed within the spline joint.
    There are some cases where it is perfectly justifiable to use 4HI at speeds of 35-50mph, for example on 2-lane, reasonably flat, not-too-twisty dirt roads where there is plenty of safe maneuvering room and good visibility, and extra traction is needed. Other examples would be driving in light snowy conditions on pretty-flat and reasonably wide roads where it may be safe to be doing 30-40mph. In a desert / dune-running situation, course depending, one could easily do 45-60mph (and more) in 4WD without undue safety concerns.
    Dm93 likes this.
  11. Apr 15, 2022 at 7:18 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I will add that if your tires are not matched and/or are unevenly worn it will put excessive strain on the driveline even going straight, on 4wd/AWD vehicles it's very important to have matched tires to prevent driveline bindup.
    GilbertOz[QUOTED] likes this.
