Loud Whine and P0010 Code After Timing Chain replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by theduckbutter, Feb 21, 2015.
  1. Feb 21, 2015 at 7:07 PM
    theduckbutter
    theduckbutter [OP] Well-Known Member
    2005 tacoma access cab 4x4
    350lb custome leaf bender bumper overkill
    Hi there.. Finally I got all the parts together and after Installing Full Timing Chain Kit, Installing New Timing Cover, Oil Pump, Water Pump, Idle Pulleys, and lot more, I finally started her up tonight.
    Loud Whining after start up and:
    P0010 Cam Position Actuator A Bank 1 Ckt Malfunction.
    Any Suggestions?
    2005 2.7 Tacoma VVT-i :confused:
  2. Feb 21, 2015 at 10:08 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i bet the cam gear moved. it can be locked or unlocked
  3. Feb 22, 2015 at 5:49 AM
    Blacktaco2042
    wisconsin
    also factory or a/m waterpump?
    i have seen the aftermarket water pumps gaskets hit the impeller and make one hell of a noise. i have seen it on one factory pump also
  4. Feb 22, 2015 at 10:41 AM
    theduckbutter
    timing seems ok when it runs.. motor sounds smooth except for loud whining. Water pump is ok not the culprit, not sure about the cam gear what you mean on that..
    I used Silocone DioElectrode grease on all the electrical fittings when I re-connected all the electrical connections.. never done that before now. wanted to make sure moisture was kept out.
    Changed out idler pulleys and pulled Cam Shaft position sensor and cleaned it.. Still bad whining
    Whining sounds like a gear drive in a hot rod motor...
  5. Feb 22, 2015 at 11:02 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Feb 22, 2015 at 1:06 PM
    theduckbutter
    I lined all the marks up on chain to pulley marks.. don't know if it's too tight. when i pull the oil fill cap off in the valve cover, I don't here anything whining in there. But it's really loud. I just pulled Crank Shaft pulley and re-greased it and front main seal. Took the alternator in to be tested; it's ok. oiled the serpentine tensioner pulley bearings.
    The Timing cover came with Oil Pump gears already installed. I assumed they got oil in them when I filled motor with oil..
    Should I have filled oil pump area in Timing cover with oil before I started maybe? Im pullling the plug right now.. expected oil to flow out when I do..
  7. Feb 22, 2015 at 1:10 PM
    theduckbutter
    man.. how would I know if the chain is too tight? Its the same size as old one and I matched up marks.. This whole job made me so nervous about messing one thing up.
    Uncharted territory for me. Figure there are about 7 tensioners with cheesey plastic pieces that push on the chain.
  8. Feb 22, 2015 at 1:14 PM
    theduckbutter
    Thats another thing.. I have no idea where my oil control valve is.. I am aware of the camshaft position sensor towards the top of the motor than the crankshaft position that goes in the drivers side timing cover but not sure about the oil control valve.
    Looked it up in service manual and it looks like the camshaft position sensor
  9. Feb 22, 2015 at 2:12 PM
    theduckbutter
    CAMSHAFT TIMING OIL CONTROL VALVE
    ASSEMBLY - Thats one of the things the ODB2 code says to check but I can't seem to find it..
  10. Feb 22, 2015 at 2:55 PM
    Blacktaco2042
    wisconsin
    sometimes if needs to run to get oil in everything and they the noise will go away i seen that before
  11. Feb 22, 2015 at 4:49 PM
    theduckbutter
    Never took the cams out.. I just pulled the allan bolt out that covers the chute into the oil pump.. was thinking maybe the oil pump needed to be primed. Oil poored out, so that doesnt seem to be the problem.
    Let the truck warm up last night prob for about 5 or 6 minutes.. was thinking the same thing that oil would get everywhere and sound would stop..
    I'm going to go to the dealer tomorrow and pick their brains..
    Allready got it all fastened up, and then realized that I had left out a tensioner from the 2nd chain assembly. spent a whole day pulling it off and redoing the whole inside again..
    Anyways feel like I am out of ideas at this point.
    Hope its not coming from the inside, I suspect my new oil pump for some reason..
    Thanks again
  12. Feb 22, 2015 at 5:38 PM
    Blacktaco2042
    wisconsin
    try using a screwdriver to pin point where it coming from
  13. Feb 23, 2015 at 3:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    I think he means 'try using a screwdriver as a poor man's stethoscope' to pinpoint the noise.
  14. Feb 23, 2015 at 3:57 PM
    theduckbutter
    Thanks- I have been using my biggest phillips screw driver all over that motor. This weekend I will take it a part again and this time I am looking at the lower secondary chain gears that I think are rubbing together.. Thanks for advice guys.. Third time is a charm hopefully on this one.. As promised in my other thread, I am going to do a very thorough write up when this is all over. Followed by selling my truck immediately and starting a a Willy's Wagon build to be used as my daily driver..
  15. Mar 1, 2015 at 9:56 PM
    theduckbutter
    Thanks for help. Took me three times pulling apart but I got really fast and now have some vdry good advice for anyone taking this on. Lots of learning she's running good now. Only took a month and a half. My write up will save anyone from taking that long
    Nickp4687 likes this.
  16. Mar 1, 2015 at 10:22 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Looking forward to your write up.
