louder plug and play horn
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Aug 19, 2020.
  1. Aug 19, 2020 at 7:40 AM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    hello....seeking a louder horn for my "single horn" 2019 SR model taco...something plug and play...any suggestions
  2. Aug 19, 2020 at 7:41 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  3. Aug 19, 2020 at 8:02 AM
    kiki111
    Tacoma 2.7L SR
    or will hooking up a 2nd tacoma horn make it louder???
  4. Aug 19, 2020 at 11:02 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The number of horns will only affect how loud it is by a few decibels. It will sound nicer, multiple horns in harmony but not louder
  5. Aug 19, 2020 at 11:50 AM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Did install 4 horns on mine and put a relay on the second pair and connect to the battery directly and use the stock horn as trigger to prevent overload to avoid blown fuse.. additional 100 db :D
    b3itz likes this.
  6. Aug 19, 2020 at 1:33 PM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    You may want to check the math on that. If you have a 100 dB horn and add another 100 dB horn it is not equivalent to 200 dB. It is closer to 103 dB.
    Hella supertones definitely get peoples attentions since they are a bit louder than stock and very different sounding.
  7. Aug 19, 2020 at 1:38 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
  8. Aug 19, 2020 at 4:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The Hella horns either blues or reds, are bolt up, make a jumper, and sound away!
    hellfire0480[QUOTED] likes this.
