Louder then normal Taco tick this morning...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ::childstoy::, Feb 14, 2011.
  1. Feb 14, 2011 at 8:34 AM
    ::childstoy::
    ::childstoy:: [OP] Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Started her up this am and noticed what sounded like a valve tap more then the Taco tap. Even opened the hood to check it out. Seems to be coming from the driver side. It was actually the warmest morning in months or I would have just blamed it on the cold.
    Truck is ready to hit 9k. Just had the oil changed 2 weeks ago. Sounded a little better by the time I got to work but still louder then normal.
    Anyone else experience this?
  2. Feb 14, 2011 at 8:39 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Mine does seem to tick louder at times...maybe I'm just paying more attention sometimes...or maybe my music is turned down too quiet. :D
  3. Feb 14, 2011 at 8:40 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    x2
  4. Feb 14, 2011 at 8:42 AM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    who changed your oil and what did they put in it
  5. Feb 14, 2011 at 9:01 AM
    ::childstoy::
    Southeast, PA
    The stealership did. I have the free maintenance for 2 years so I'm just letting them do it. I'm gonna go check it out to make sure everything is as it should be.
  6. Feb 14, 2011 at 9:05 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    check your oil I dropped below the min level once and the tick was louder. This might not be the case but its an easy check.
  7. Feb 14, 2011 at 9:10 AM
    ::childstoy::
    Southeast, PA
    Yeah... I'm gonna go look.
  8. Feb 14, 2011 at 12:37 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I find my truck ticks more on the DS than the PS. Also, if you're parked right beside your house (or any other building for that matter) the tick will be amplified, as it bounces off the wall of the house.
  9. Feb 14, 2011 at 6:29 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Mine does it more from the d-side as well and is actually more audible inside the cab
  10. Feb 14, 2011 at 7:01 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Cats or transmission flex plate. I've had both...both were covered under warranty.
  11. Feb 14, 2011 at 7:43 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Cursed tick! Why do you haunt me!?
  12. Sep 11, 2014 at 2:02 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    I have a random tick that sounds from my drivers side that came out of no where. I speed up it gets faster same as slowing down. Sounds like a rock in tread but it's more along the lines of a creak and not a tick. Anyone have suggestions in what to look at?
