Lousy gas mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by hcar, Jan 8, 2009.
  1. Jan 8, 2009 at 7:33 PM
    hcar
    hcar [OP] New Member
    nj
    tacoma limited
    Hey guys. I'm new to this forum. Looks like a cool place for some of us who are rookies in tacoma ownership. I have a questions I'm hoping someone will be able to answer. Just purchased a 2001 Tacoma Limited. The truck is super clean and looks like it has been well maintained. No problems reported on car fax. Anyway, love the truck but only have one problem which is really bugging me.... Before buying I researched and saw from several owners claiming to get anywhere from 17-25 mpg depending on wheather conditions, load and style of driving. I'm a very conservative driver who tops off at 65 mph on the highway and barely getting 15 miles p/g without much city driving. Is this common?? Is there anything I should know or do to the truck that would help getting at least 17-18 mpg?? If anybody has the answer, please respond, it will be greatly appreciated.
  2. Jan 8, 2009 at 8:07 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How many cylinders do you have? I used to get 19MPG with mostly highway driving before I sold my truck. You should change the spark plugs and probably the plug wires while you're at it too. Changing over to synth oil will gain you 1 or 2 MPG as well.
  3. Jan 8, 2009 at 8:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!!
    for a little better mileage...all these will help......make sure your tires are properly inflated, change over to synthetic oil, make sure the spark plugs are good, change the fuel filter, clean the throttle body, seafoam it........lots of different things can affect your mileage. check out your fuel filter though........if it looks kinda old or like its been on there a while....change it, you may pick up some better miles with that initial change.
  4. Jan 9, 2009 at 4:59 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Another factor is that you're stuck with the winter formulated gas until late spring. That causes about a 10% drop in mileage.
  5. Jan 9, 2009 at 5:10 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2... Winter blend gas = worse gas mileage.
  6. Jan 9, 2009 at 7:04 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Also, I would change the fuel filter and check the plugs.
  7. Jan 9, 2009 at 8:06 PM
    Allens_Piece
    Allens_Piece Well-Known Member
    Anchorage Alaska
    09 4XTRD Dbl Cab
    Wheels/tires 3" Toytek coilover w/ OME rear springs (no blocks) Billstien shocks, K&N CAI, TRD Exhaust.
    Uh winter gas? what do you guys mean? how/why would it be different?
  8. Jan 9, 2009 at 8:12 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Yeah I'm not sure they send us winter blend gas in Florida. lol
  9. Jan 9, 2009 at 8:17 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I believe it is mixed differently in the winter for smog control in certain areas of the country
  10. Jan 9, 2009 at 11:27 PM
    kingsportal
    kingsportal New Member
    houston
    07 prerunner
    basic
    inflate tires and get k/n air filter
  11. Jan 10, 2009 at 12:38 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Refineries use more ethanol when blending it into gasoline during the winter months IIRC, can't remember why they do though. :rolleyes: More ethanol means less MPG.
  12. Jan 10, 2009 at 2:40 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    Since I bought my '04 (3.4L) Tacoma DC in March, I have religiously recorded 37 (every) fill-up and resulting mileage. I have a graph. OK, anal, but I too was expecting great MPG with a smaller truck (relative to my F350). I did all the tricks, airfilter, spark plugs, tire pressure, etc. My high was 21.5MPG on road trips, my around town average was ~18. When I installed the lift and tires, the highway mileage came down to 18.5 and around town went to ~16.8 MPG. (I can live with that, my F350 was 9). Around August, the Tacoma MPG took a big nose dive...20%+...I think this is around the time NY went to 10% ethanol (I can't get anything else now), and it may have to do with "winter gas"...but I don't know what that is? or if they even still have it when they already put 10% ethanol in? My question I guess is has anyone else seen this drastic change with ethanol...and I guess in the bigger picture why are we as a country doing it? If we add +10% but get -20% less MPG, we as a consumers are actually buying more gas derived from oil! (The break even point would be +10% ethanol/-10% MPG).
    I hope some Chevron engineer chimes in, I'd like to get to the bottom of this...:confused:
  13. Jan 10, 2009 at 2:24 PM
    Roland
    Rhode Island
    The winter formulation is a requirement in the northern states. One upon a time when engines were carburated, engines would have issues when it got cold. To help keep people's cars running correctly laws were passed requiring the gas companys to reformulate the fuel in the winter months. I don't think that modern fuel injected engines would still have the problems but the laws are still in effect and the gas in the winter has less available BTUs per gallon. Less energy per gallon = more gallons burned to go the same distance.
    Sorry I'm a bit vague but I don't remember all the details and I don't want to put the wrong info out there.
  14. Jan 10, 2009 at 2:43 PM
    SRFIVE
    Upstate NY
    '09 SR5 AC
    What size tires? and do you have a lift?
    Thanks for the info, unfortuantely I already run synthetics, have a K&N filter and changed the plugs early in the summer.
    I guess I am jacking this thread, but maybe we'all learn something... When I bought the truck it got 16 MPG, it slowly climbed to 18.5 as I went to synthetics, changed the air filter, plugs, TLC, etc. Trip to Maine even got 21.5 MPG. Then I installed the lift and tires, kinda leveled out around ~17 MPG. Winter came, NYS switched to 10% ethanol and...nose dive, some 4WD because it's winter, but 13MPG?!? What gives?
  15. Jan 11, 2009 at 11:29 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    not to hijack this thread, but sr5 where did you get your hood from?
  16. Jan 11, 2009 at 1:03 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
