Love my new 4x4 Sport , but
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mamaluke, Jul 30, 2022.
  1. Jul 30, 2022 at 6:08 AM
    Mamaluke
    Mamaluke [OP] Member
    Dino
    Live in the country so I need the 4x4 for snow . This is a road truck for me , no 4 wheeling . I have just one gripe , it pulls to the right . I did a search and it looks like a problem with a lot of trucks . Anyone have any luck with the dealer fixing this without a big hassle ?
  2. Jul 30, 2022 at 6:12 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    If alignment is good then it’s your tires. Try to switch front left to right. If it pulls toward the opposite it’s your tires. If if the same side then it’s your alignment
  3. Jul 30, 2022 at 6:15 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Is this a new truck, or a new-to-you truck? If it's new, take it back to the dealership, if it isn't, get the alignment checked or check the tires.
    Beerpayzdabillz and tacoshell88 like this.
  4. Jul 30, 2022 at 7:16 AM
    EarthCruzn
    EarthCruzn Well-Known Member
    Florida
    2022 TRD V6 4WD Manual 6 Speed
    DCSB SPORT
    I have a 2022 Sport it drives straight as a arrow,... no hands required.
    Is this new or did it pull during the test drive.
    Either way the dealer should fix it for free, unless they play the "It was fine when you left, why didn't you say something" card.
    Someone else messes with it and somethings wrong,... the dealer will tell you should have come here anyway.
  5. Jul 30, 2022 at 7:19 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    It shouldn't pull, I would take to dealer.
  6. Jul 30, 2022 at 7:19 AM
    eurowner
    eurowner Duke Sky
    Scoty
    What psi is in all four tires?
    How crowned are your roads?
    Chew likes this.
  7. Jul 30, 2022 at 7:21 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If a steering/alignment issue, you have 1 year or 10k miles which ever come first to have it in warranty....they only do it once in that period.
  8. Jul 30, 2022 at 9:02 AM
    Mamaluke
    Dino
    It's a new 22 . I'll call the dealer Monday . Tires are all 34 psi .
    Thanks for the replies .
  9. Jul 30, 2022 at 9:12 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Same thing on a 2000 T4R I bought new. It was the tires.
    The dealership tried aligning it, still pulled to the right so I brought it back.
    The dealership said everything was in alignment, so I called toyota corporate.
    They called the dealership, who called me, and they put on a set of 5 Michelins.
    Problem solved.
    TA2016 likes this.
  10. Jul 30, 2022 at 9:23 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The rear axle thrust angle is likely out. Toyota dealers, and most tire shops wont make this adjustment as it requires loosening the rear leaf spring clamps and is not part of the official Toyota procedure, which never mentions the rear axle.
    Go to a proper shop, that specializes in alignments, and you will be fine. There is no truck that is doomed to pull right, in the hands of a qualified alignment tech. They’ll correct the thrusts angle and send you on your way.
    oconnor likes this.
  11. Jul 30, 2022 at 9:39 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  12. Aug 4, 2022 at 3:25 AM
    Mamaluke
    Dino
    Dealer did a front alignment . All good . No hands , straight as a arrow .
    SSMTRDOR, eurowner and 07RedTacoDawg like this.
  13. Aug 4, 2022 at 9:05 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    This is the first I have heard of this. Alignment maybe, tires?
