Love the truck, but the beeping is killing me
Discussion in '3rd Gen. Tacomas (2016-2023)' started by parkerjm, Apr 5, 2024.
  1. Apr 5, 2024 at 7:21 PM
    HockeyTaco10
    HockeyTaco10 Well-Known Member
    2023 Lunar Rock
    Spend 20$ and get the obd2 Carista and get the app and all your beeping annoyances will melt away in less than five minutes of effort
    Maximumdarkside likes this.
  2. Apr 6, 2024 at 5:58 AM
    MacGyver2394
    MacGyver2394 Active Member
    Connor
    2020 MGM DCSB TRD OR
    so you don’t have to rip it out? You can just like pop the top off and remove some internal bit of the little speaker?
  3. Apr 6, 2024 at 7:23 AM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    Me to....USA Bikini Top with perfect plumpys..does it get any better?I submit that it
    does not...lol
    :101010::oldglory:
    Steves104x4 likes this.
  4. Apr 6, 2024 at 7:26 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    as long as you don't check your mirrors!
  5. Apr 6, 2024 at 8:10 AM
    ksnook
    ksnook Well-Known Member
  6. Apr 6, 2024 at 10:45 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    AmateurTaco1313 likes this.
  7. Apr 6, 2024 at 10:59 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’m not complaining……..just have a hard time reading
  8. Apr 6, 2024 at 1:21 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    "This was my worst beep which I have eliminated by disabling the switch within the seatbelt buckle latch." quote
    Can you explain how to do this? Pics would be great too. Thanks.
  9. Apr 6, 2024 at 6:34 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Yes, no hacks, no ripping, no damage, no work that cannot be easily reversed.
    At 4:28 in the video linked above you can see the bottom of the buzzer. There are six segments around the outside of the buzzer that latch onto the flat bottom of the buzzer. I used a flat bladed screwdriver that was wider than the distance between the buzzer bottom and the printed circuit board to pry two adjacent segments outward and the top cover separated from the bottom.
    Inside there is a flat disk that you might want to mark as to which direction is up - I did not pay any attention at the time of my disassembly and I do not know if it matters at all, as upon reassembly of the buzzer it worked just fine. May have been 50/50 lucky or the direction of the buzzer does not matter, really do not know. Just a suggestion to eliminate any problems.
    Reassembly: just put the disk back in and snap on the cover.
    I put my buzzer back together because I did not want to be one of those whom are always driving down the road with my blinker on. Also, like someone mentioned it is just a comforting sound to me, most all the other sounds it makes are not comforting.
    The prying works by placing one side of the flat bladed screwdriver on the PCB outside the diameter of the buzzer and the other side of the flat bladed screwdriver at the inside edge of the buzzer bottom. Rotate the screwdriver and you move one of the six latches outward loosening the latch. You can use two screwdrivers, have someone help you or just hold the top cap bent away from the bottom. Don't worry about scratching the PCB surface with the screwdriver, just stay away from R7033 and C7018.
    An electronic hobbyist could also remove the needles from the cluster and unsolder the two terminals through the PCB from the other side.
    Just had a thought on storage of the parts: tape the disk to the outside top of the cap and it will always be there for anybody to reassemble.
    PCB = Printed Circuit Board.
    @canuck guy I'll have to get to your question later when I do a write up.
    MacGyver2394[QUOTED] likes this.
  10. Apr 6, 2024 at 7:30 PM
    MacGyver2394
    Connor
    Detailed and well thought out, thanks for the great tips!
    Toycoma2021[QUOTED] likes this.
  11. Apr 6, 2024 at 7:52 PM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    You can turn some of that off with the TIS Techstream software as I recall..
  12. Apr 7, 2024 at 6:08 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Removed that beeper months ago when I had the dash apart for subwoofer install. I consider the removal of that beeper the more important “audio upgrade” I kinda didnt want to lose turn signal but it was worth it for all the other beeps. If I recall, my emergency braking beep still works. Now I’ve been pondering if I can just install a relay somewhere in the dash just to make the turn signal click…
  13. Apr 7, 2024 at 6:42 AM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    I disconnected the key switch in the column. Manual transmission. Stopped the beeping on start up. Seatbelt is still operational for now, kinda annoying when travelling a couple of hundred feet at the farm. I'm going to look into the seatbelt switch.
  14. Apr 7, 2024 at 6:48 AM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    I've never heard my sr beep, it must be high pitched. I can hear the turn signal and it dinged at me a few times, but the seatbelt thing I can't hear. At least there is a positive to the hearing loss. lol
  15. Apr 7, 2024 at 8:20 AM
    #35
    Blak Shinobi
    taco
    n/a
    you can make the sounds manually when you pull the lever just make *clicking sounds* with your mouth
    Malvolio likes this.
  16. Apr 7, 2024 at 8:23 AM
    #36
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    This certainly works and it works well.
  17. Apr 7, 2024 at 8:34 AM
    #37
    Toycoma2021
    Find a 12VDC noise maker that you like with a high resistance and it could be wired in with a few diodes to keep the right and left separated. When Radio Shack existed this would be easy. A regular old fashioned electromechanical flasher may take too much current and make the vehicle see an error and flash faster or slower - you could try it. The turn signals are generated and powered by the instrument panel.
  18. Apr 9, 2024 at 4:50 AM
    #38
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    So for those who may want to possibly reinstall the Piezo speaker at some point here is a source for the factory part.
    Toycoma2021 likes this.
  19. Apr 9, 2024 at 6:54 AM
    #39
    Wisky57
    Wisky57 Well-Known Member
    2021 Army Green Toyota Tacoma TRD Off-Road
    I drive a lot of country roads and the truck beeps at me for every curve. Button is nice to click off but is helpful in the city. The door beeping is annoying. Thanks for posting that earlier.
  20. Apr 9, 2024 at 6:58 AM
    #40
    gumbine
    gumbine Well-Known Member
    23 TRD Offroad DCLB
    at this point the beeping door is really the only thing that annoys me with the truck. sometimes i like to just sit there for a minute with the door open before hopping out, but half the time i get plagued by the beeping because i didnt shut of the engine and open the door in the correct sequence
