Love to off-road the unusual
Discussion in 'New Members' started by Snyderman101, Oct 12, 2020.
What’s a good locker for a 2wd truck?
  1. I’ve heard a Targa (sp?) is a good cheap option
    0 vote(s)
    0.0%
  2. What are more options?
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Oct 12, 2020 at 7:11 PM
    Snyderman101
    Snyderman101 [OP] New Member
    David
    2000/01 Tacoma single cab 2wd 2.7l
    Camper top/basic recovery gear
    Hey there y’all, this is my first Tacoma I’ve ever owned and I love it. It’s a 2000/01, which means the engine is a 2000 model and a lot of the body is 2001. Ask me how I know, haha! Anyways, I’m a family man and all about built not bought (mostly cuz I’m broke because Teenagers) and modding stuff myself.
    I’m not new to off-roading, I’ve done enough riding/spotting for friends and was a downhill mountain biker/trail builder that I know how to spot and coach good lines. I’ve also driven my Subaru Impreza Outback and later Forester on many trails folks have been surprised to see me on. Anyways, I’m excited to add a locker and some lite mods while the kids are still home and maybe a full SAS, twin stick, 4x4 conversion later after they’re gone.
  2. Oct 12, 2020 at 7:16 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  3. Oct 12, 2020 at 7:19 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard David
  4. Oct 12, 2020 at 10:52 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Welcome!
    Bigdaddy4760 likes this.
  5. Oct 12, 2020 at 11:13 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Never heard of a targa, are you thinking TORSEN?
    If so that's a worm gear LSD not a locker, more better than an open diff, but more for road racing not off-roading.
    Now the best cheap locker?
    Probably OEM, they could be had on both the Tacoma and 3rd gen 4Runner 96-00.
    If you can find a junk yard one then you're in business. I went this route got a 4:30 from an auto (get the front diff for the gears too if you're not matching) 4Runner (97) at a U-Pull-n-Pay hub to hub for $300 I think rebuilt it end to end for a couple bucks bullet proofed the actuator and bolted it into my '00 Runner did the blue wire (or grey wire?) Mod so I could lock up in 2WD and it was phenomenal.
    Now, if you get one off a 4runner they are coil sprung so you either need to mod up your existing housing slightly to drop in the e-locker 3rd memder or cut all the coil buckets off and add spring perches to the 4Runner housing but the drums and WMS to WMS should be identical.
    The OEM E-Locker could be had in 4:10 4:30 and 4:56 flavor, 4:56 is rare as a jackalope 4:30 is most common by far which with a manual trans pairs great with 32" tires.
  6. Oct 12, 2020 at 11:34 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  7. Oct 13, 2020 at 12:13 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Welcome to TW
    Only Targa I’ve herd of was on a Porsche.
  8. Oct 13, 2020 at 7:38 AM
    Snyderman101
    David
    Oh wow, ok! We have an LKQ pick your part and I work at a shop called Truck N Trailer USA, I get cost with Meyer, P&E distributors, and Keystone. So I’ll definitely check out LKQ first and then can cut and reweld perches ie whstever fab work needs done! Thanks!
  9. Oct 13, 2020 at 7:44 AM
    Snyderman101
    David
    Have y’all heard of a Spartan Locker? That was the one my buddy bought and I have the 2wd Taco so I won’t be putting one in the front at all.
  10. Oct 13, 2020 at 3:09 PM
    TnShooter
    Deogee
    STOCK
    Not until I did a search.
    Looks like a few guys have run them.
    Premature engagement can be an issue if you “gas it” to hard according this
    https://www.tacomaworld.com/threads/spartan-locker.280281/
  11. Oct 13, 2020 at 8:28 PM
    Key-Rei
    Key
    Florida
    Yeah that's a great place too, if you can have them pull the wiring for it too, I believe Marlin Crawler or Inch worm off road sells a harness you can use but it's nice to have the full OEM set-up too.
    There's also a locker button on the dash and a locker control module that's in the driver's kick panel.
    Again you can buy the aftermarket harness and do a simple switch and relay to get it to work without all that also but most trucks come at least partially wired for the locker.
    My Runner had the wires from the locker computer to the gas tank pass through area just used the harness from there back to the locker and plugged the brain and switch into the existing plugs and I was in business.
  12. Oct 16, 2020 at 4:52 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
