Loving my LCE Headers!
Discussion in '4 Cylinder' started by tacomalex, Dec 5, 2011.
  1. Dec 5, 2011 at 5:34 PM
    tacomalex
    tacomalex [OP] Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I finally found the time to install them Saturday morning, and all I can say WOW! Anyone who wants to add some real power to their 4 banger needs to get a set.
    It isn't like installing a CAI and thinking you have gains cause you just spent alot of money, so of course it added 10 horsepower.. You can really feel it. Anyone with a 5 speed knows, when you're trying to punch it out into traffic, or just cause you want to.. The shift from 1st to 2nd gear always leaves you wishing your engine could push a little harder, keep up the acceleration. These headers give you that extra zip the 4 banger has been lacking. Low end power, better throttle response, it makes me want to put my truck on a dyno just to see the gains firsthand.
    I can't wait to install my URD MAF Calibrator to get my truck dialed in with the Volant intake and LCE Headers. Seriously, get a set! :D
  2. Dec 5, 2011 at 8:10 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Got mine in too over the weekend. They are nice.
  3. Dec 5, 2011 at 8:13 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    LCE makes some great stuff.
  4. Dec 5, 2011 at 8:16 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    so are you as happy as OP on your install ?
    tacomalex > that is good to hear, i am a 4 banger and looking into more power also.
  5. Dec 5, 2011 at 9:09 PM
    MadTaco461
    CA
    Kinda stock
    They fit like a glove and they happen to be long tube headers for my truck. The worst part is getting the old ones off. Look at them and you can tell they do very good craftsmanship. Great grunt off the line to about 3K and wants to keep revving and clean exhaust note.
  6. Dec 5, 2011 at 9:11 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    A nice little correction, header not headers...only one set :p
    Could not agree more that a header is the best bang for the buck after re-gearing. I have the DT header and LOVE IT!
  7. Dec 5, 2011 at 9:12 PM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    yeah from the literature I read that came with mine (for a 2nd gen) they are long tube equal length headers.
    I took out my intake, and some thing (no idea what it was) that was attached right above my headers and they came out pretty easily. The heat shield was harder to get out.
  8. Dec 5, 2011 at 9:14 PM
    08pretaco
    az
    The EGR pump would be my guess
  9. Dec 5, 2011 at 9:17 PM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    thanks! my car knowledge is limited to write ups and instructions I get with parts I order, so I'm still learning.
  10. Dec 5, 2011 at 9:21 PM
    MadTaco461
    CA
    Kinda stock
    Re-gearing is amazing too. Already going up even more from my current 4.56 to get me some snap.
  11. Dec 5, 2011 at 9:24 PM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I want to re-gear so bad.. I have 32's right now, I plan on getting the Icon 3 leaf AAL to replace my toytec one, and going up to OME 885 coils once my current tires wear out and go with some 255/80/17 M/T's.
    What size tire are you running with your 4.56's? How are your RPM's at highway speeds?
  12. Dec 5, 2011 at 9:36 PM
    MadTaco461
    CA
    Kinda stock
    I'm a different motor and transmission gear ratio than you, but use a gear ratio calculator on google like this. With 32's at 70mph I'm about 2600 rpms. Roughly took 10mph off at highspeed and 5mph at low. You are 4x4, that is a pricey change.
    http://www.grimmjeeper.com/gears.html
  13. Dec 7, 2011 at 6:37 PM
    tacomakyle
    tacomakyle Member
    kyle
    Manitoba Canada
    03 2.7l SR5
    3" suspension lift
    does LCE headers for the 03 2.7L? I was on there website and there were only headers for 05 and up tacos
  14. Dec 7, 2011 at 9:24 PM
    MadTaco461
    CA
    Kinda stock
  15. Dec 8, 2011 at 7:48 AM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Are you running the LCE header with the rest of your exhaust stock? How does it sound?? Im just worried about getting just the header and having that bumble bee sound.. I dont want to get a cat back or different muffler just more power! And as close to stock sound level as possible. Also any increase in gas mileage??
  16. Dec 8, 2011 at 11:23 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    are theses CA legal or no?
  17. Dec 8, 2011 at 11:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    yes. almost the same. no bumble bee. very close to stock. yes, 1-2 mpg (30" tires)........
  18. Dec 8, 2011 at 8:45 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  19. Dec 9, 2011 at 7:04 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  20. Mar 23, 2013 at 1:24 AM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Damnit I need this, anybody know where I can get a lightly used header pm me he he
