Low 4 Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ohumphries, Aug 31, 2012.
  1. Aug 31, 2012 at 2:53 PM
    ohumphries
    ohumphries [OP] New Member
    I have a 2009 ext. cab 5 speed and recently it will not shift into 4lo. I have used 4hi on a regular basis and last week decided to shift to 4lo and could not get it to engage. I went through all of the troubleshooting to no avail. Also, pushing in the clutch to start the engine quit and the clutch override switch has to be pushed. I am thinking it is an electrical issue, maybe they use the same circuit or solenoid? Any help would be appreciated. Thanks.
  2. Aug 31, 2012 at 2:58 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    were you stopped and in N?
  3. Aug 31, 2012 at 6:31 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    The clutch switch is the issue here. If it ain't working to start the engine, it won't let it go into 4 lo either.
  4. Aug 31, 2012 at 7:55 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Neutral is not necessary to shift to 4lo on a manual trans tacoma.
  5. Aug 31, 2012 at 8:00 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Exactly! If the switch is secure in the holder and the tab on the pedal depresses the plunger fully, then try putting a jumper in the connector. If it will crank with the jumper, remove it, and replace the clutch safety switch. Do not confuse it with the cruise clutch switch if equipped, which is at the top of the pedal stroke.
  6. Sep 14, 2012 at 7:52 AM
    ohumphries
    Thanks for the info. For some reason the clutch pedal tab was not depressing the switch. A small spacer added to the tab and all works perfectly. Thanks again.
