low beam issue
Discussion in 'Lighting' started by TRD2010SpeedwayBlue, Dec 7, 2023.
  1. Aug 10, 2024 at 2:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If I’m remembering correctly, the relays are side specific, right? The Morimoto harness has 2 relays. Both failing at the same time, that same way is unlikely, in my opinion. A relay failing in 6 months can happen, electronics fail, usually when they’re really new or really old. Still thinking the controller is faulty.
  2. Aug 10, 2024 at 2:30 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue [OP] Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    oh no i have 1 moto controller for the whole unit as they are bixenon retrofits not factory lights with an hid kit.
    Bought the relay from TRS on Amazon Dec 2023.. Do you think the retrofit source will honor a warranty if i figure out how to determine there’s a fault??
  3. Aug 10, 2024 at 3:58 PM
    Pugga
    Massachusetts
    It’s worth giving them a call, they helped me sort my set out. They may also have some diagnostic tricks to help you as well.
  4. Aug 13, 2024 at 2:01 PM
    TRD2010SpeedwayBlue
    Brandon
    So a Tuesday update.
    0 issues on sunday after multiple on and off cycles and 0 issues on Monday I tried the lights multiple times at night as well.
    So weird!
  5. Nov 14, 2024 at 2:15 PM
    TRD2010SpeedwayBlue
    Brandon
    After no issues for several months…. my issue is back intermediately no driver low beam/high but after a few power cycles low beam turns on and works as should.
    Think i am going to get a set of denso slim ballasts to start as my bulbs (cbi osram) are only about 5 years old
