Low beams and fog lights stopped working 2021 4x4 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by speed140, Jul 11, 2024.
  1. Jul 11, 2024 at 8:36 PM
    speed140
    speed140 [OP] Member
    2021 Tacoma 4x4 SR5
    none
    Good evening. I'm not sure when this started. Either yesterday or today. The high beams work but not the low beams and also no fog lights. I've tried the switch in the auto and manual position. The dash indicators light up. No mods to the truck or anything. We had some hot weather the last few days. I found the fuse block under the hood but I'm not sure witch one to swap out to test it. I thought someone here might be able to help. I thank you for your time.
  2. Jul 11, 2024 at 8:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the 15A H-LP LO fuse
    Stevie17, speed140[OP] and Dm93 like this.
  3. Jul 11, 2024 at 9:05 PM
    TnShooter
    Deogee
    STOCK
    FWIW, I am shooting blindly at the logic of the Body ECU.
    But knowing that 2nd Gen fog lights will NOT come on unless the Low beams are on, I'm going with checking the Lo beam fuse first.
    The Dimmer and Low Beam relay are controlled by the Body ECU. Which are operated off inputs from the headlight switch.
    Keep us posted OP.
    Stevie17 and speed140[OP] like this.
  4. Jul 11, 2024 at 9:15 PM
    speed140
    2021 Tacoma 4x4 SR5
    none
    Thank you. I'm going to try replacing that H-LP LO fuse in the morning. Also what you said about the fogs only coming on if the low beams are working makes sense. I'll find a good parts store. Thankfully I don't have to work whiles it's dark. I wanted to go to the desert this weekend but that might have to wait.
  5. Jul 11, 2024 at 9:22 PM
    TnShooter
    Deogee
    STOCK
    Do you have a voltage meter?
    I'd rather test a fuse than just replace it. (for cost savings).
    I like to know, before I replace.
    Also, check under the fuse box. Some times they give you extra fuses.
    If not, swap the fog fuse and Lo beam fuse. They are both 15A. I seriously doubt they are both blown.
    Stevie17 likes this.
  6. Jul 11, 2024 at 9:25 PM
    speed140
    2021 Tacoma 4x4 SR5
    none
    Okay yes. I'm assuming I would just check it for continuity, right?
  7. Jul 11, 2024 at 9:27 PM
    TnShooter
    Deogee
    STOCK
    I'd check for power on both sides of the fuse.
    I like to check the fuse installed. That way I know i have power to the fuse.....
    The fuse has 2 little bare spots on top of it, just for that reason.
    A test light to check them is even better.
    Stevie17 and Chew like this.
  8. Jul 11, 2024 at 9:28 PM
    speed140
    2021 Tacoma 4x4 SR5
    none
    Oh got it. Okay.
  9. Jul 11, 2024 at 10:29 PM
    caribe makaira
    Caribbean, Puerto Rico
    Remove the Mirror Heater fuse (15A) and place in the suspected blown position (H-LP LO), test function.
    speed140[OP], Stevie17 and Chew like this.
  10. Jul 12, 2024 at 9:54 PM
    speed140
    2021 Tacoma 4x4 SR5
    none
    Well I checked the fuse and it looked fine. I pulled both headlight bulbs and both fog bulbs and all four were shot. They must have all gone within hours of each other. Hard to tell though since I haven't been doing any night driving. Thank you again for your help.
  11. Jul 13, 2024 at 12:13 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If all 4 bulbs were blown on a 3 yo truck, I’d suspect something else is wrong.
