Low beams and parking lights out at same time..highbeams and fog lights work, any idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lord_Commander, Oct 8, 2015.
  1. Oct 8, 2015 at 6:55 AM
    Lord_Commander
    Lord_Commander [OP] New Member
    2007 TRD offroad
    Hey all. Did a search for this topic and didnt come up with anything so starting a new thread.
    So, my lowbeam lights and my parking lights both went out at the same time the other day. The fuses are fine, even switched the highbeam and lowbeam fuses, no difference. High beams work just fine as do the fog lights. So basically, I drive with fogs and brights on...
    So its not the fuses, anyone have an idea what it could be? Potentially the relay?
  2. Oct 8, 2015 at 9:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the DIM Relay inside the fuse panel under the hood. To check it either replace it of swap it with another like relay.
  3. Oct 8, 2015 at 11:18 PM
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
    So like all 4 in the front are out? Or just one side?
  4. Oct 9, 2015 at 4:01 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    stock....fogs never come on with highbeams
    fog are only wired to come on if switch is in lowbeam position
    so what you have is custom bs wiring somewhere
    someone has been f**King with your wiring...did it wrong, something gave up or burned something out...etc
    so, you need to unf**k it
    relays or whatever was tapped to override the defaults
  5. Oct 9, 2015 at 4:54 AM
    Lord_Commander
    2007 TRD offroad
    I have not had any custom wiring done. Yes, all 4 in the front are out, all at the same time. So, I will start with switching out the relay, and if that doesnt work will move onto wiring.
  6. Oct 9, 2015 at 5:36 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    well
    impossible to have fogs and highbeams on at same time unless you are in
    lowbeam mode, and pulling the temporary flash highbeam switch
    as it is illegal (FMVSS) to have highbeams and fogs on at same time in all us states, so
    toyota does not wire them that way. many people do custom wiring to make
    fogs come on with brights or 'fogs anytime' but in US... ANY vehicle you see on road with high beams
    and fogs at same time have been kajiggered with guaranteed, or someone is holding down
    the high beams flash switch
    it is possible to have something corroded or blown then all bets are off...but -fogs and high- ? smells fishy
    unless I have your description misinterpreted
    fogs only (low beam position but low beam not working)
    or high beams only and no fogs would be possbile
  7. Oct 9, 2015 at 9:24 AM
    Chris135
    Regina,Sk
    /\/\ he's got a point. I overlooked that but yes correct about not being able to have highs and fogs on at the same time. It's either one or the other or modify the wiring to make it work..
  8. Oct 9, 2015 at 10:38 AM
    Lord_Commander
    2007 TRD offroad
    Alright. I dun goofed. I MEANT to say brights OR fog lights. Durp.
    So let me rephrase, Brights and fogs work (not at the same time) , but no low beam or parking lights. Fuses are fine. Switch seems fine, can pull it to blink the brights and switching from off to low to bright works fine. So, I ordered new a relay and bulbs and will put them in soon. If that doesnt work, would the wiring be the next thing to look at?
  9. Oct 9, 2015 at 10:57 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    OK so now I am happy.
    but I have no advice :anonymous:
    it is rare to smoke the wiring in a non-messed up truck, so
    relay is probably gunna do it for ya
  10. Oct 12, 2015 at 6:38 AM
    Lord_Commander
    2007 TRD offroad
    Alright, so this situation is resolved. I decided to replace all the bulbs first on the off chance 4 bulbs all went out at once...and what do you know, thats exactly what happened. It seemed so unlikely to me that I didnt even consider it.
