Low Beams do not work, High beams are now Low Beams
Discussion in '1st Gen. Tacomas (1995-2004)' started by Antispin, Oct 25, 2014.
  1. Oct 25, 2014 at 1:33 PM
    Antispin
    Antispin [OP] Member
    Denver
    04 D-Cab SR5
    Hi all,
    I have a strange issue.
    2004 Taco
    Recently, my low beam setting has stopped working all together. Oddly, when I switch to my high beams, they are now only shooting my low beam lights. I searched a bit around multiple forums and found that this might be caused by a short of the connection within the steering column so I pulled the wheel off and took a look but I dont see any signs of overheating or disruption.
    Can anyone else think of a reason why this would happen?
  2. Oct 25, 2014 at 2:25 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Have you checked the relays in the fuse box under the hood?
  3. Oct 25, 2014 at 4:21 PM
    Antispin
    Denver
    04 D-Cab SR5
    Im a bit shamed to say that this problem was fixed by changing out both the bulbs.
    The perfect storm of them going out at the same time, not looking like they were blown, AND the high beams also somehow affected by this led me to believe that it was a much bigger deal than it was.
  4. Oct 25, 2014 at 5:14 PM
    CD20H
    Ben
    North Texas
    Well good deal. It could have been A LOT worse.
