Low beams out/truck won't start
Discussion in 'Lighting' started by Crimson Flam3s, Dec 20, 2020.
  1. Dec 20, 2020 at 6:23 AM
    Crimson Flam3s
    Crimson Flam3s [OP] Well-Known Member
    So I installed new headlights yesterday and while trying to aim the low beams a bit higher using the built it screw, the low beams went out and the truck won't start.
    Seems like defective headlights/wiring so gonna check the headlight fuses but not sure how that would cause it to not start in the first place, any ideas?
    Thanks:D
  2. Dec 20, 2020 at 6:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Define no start.
    Were these some aftermarket fancy things? If so, what does their support line recommend?
    Crimson Flam3s[OP] and whatstcp like this.
  3. Dec 20, 2020 at 6:47 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check all the fuses. Sounds like a short.
  4. Dec 20, 2020 at 6:50 AM
    Overlandcharlie
    Overlandcharlie Well-Known Member
    Tulsa ok
    2017 TRD OR access cab
    Toytec boss alumaseries C/O JBS UCAs CMC 1/4 “ level spacer Boss2.5 rear shocks Toytec AAL and 1” block Lo pro front recovery bumper X20 winch dynnema rope / factor 55 aluminum recovery clevis Lo pro light bar install with wireless remote RCI sliders Dobinson snorkel PRO aluminum skid TRD PRO grill Fuel 17x8.5 wearing Nitto 285s 285 spare and spare mount mods Rear recovery point Soft topper ( grey) modified tail gate snap Snail armor aluminum tailgate insert In bed - sleeping and storage platform ( with tool locker ) - carpeted Offroam RAM mount - cellular/GPS Maxtraxx knock offs and tons of recovery gear including more power puller synthetic Rugged ridge compressor ROAM storage Shiftsense mod .
    Unplug them plug the old ones back in and see if everything works . If so then probably the new headlights you purchased
    Could also just be one of them is bad
    If nothing works after you switch back check your main ground wire is still firmly attached to the frame
    Crimson Flam3s[OP] likes this.
  5. Dec 20, 2020 at 8:19 AM
    Crimson Flam3s
    Well it does crank but it won't fully start. Interior lights work, even the high beams work. The moment Fogs and low beams went out I tried to start it and yeah noticed it wouldn't start up lol
    Definitely gonna try disconnecting the new aftermarket headlights but not an expert on this type of situation, just seems weird that a headlight fuse would affect the vehicle to the point of not fully starting.
  6. Dec 20, 2020 at 8:40 AM
    Overlandcharlie
    Tulsa ok
    It’s not a headlight fuse
    Check your ground 1st. Seriously I have spent all day with an electrical problem on a Jeep only to find a damaged main ground
    I’m not saying that is it but it does sound similar
    If it’s cranking and not starting look at common problems 1st.
    battery charge less than 13 v? Are you getting a click click click when cranking - battery sounds like could use a charge
    Ground wire loose / or damaged when you were pulling the old headlights
    Starter going bad - could be ? Strike it hard with a hammer then see if it cranks
    I seriously doubt you’ve blown a fuse and if you had it would still start no problem
  7. Dec 20, 2020 at 3:06 PM
    Crimson Flam3s
    Thanks! It just seems so weird that the headlights would discharge the batt after having them on with the truck off for only 45 mind.
    I ended up recharging the batt and that did the trick, now the low beam for one of the headlights doesn't work so gonna have to replace that, wonder if it's coincidence or crappy lights but not taking any chances.
  8. Dec 20, 2020 at 3:36 PM
    Overlandcharlie
    Tulsa ok
    Oh for sure headlights will run a battery down fast - the thing is once your past 12v the battery usually won’t have enough cranking power
    Low beam being out could just be coincidental
    Glad you got it running again
