Low boost with S/C install
Discussion in 'Performance and Tuning' started by boostedka, Mar 25, 2012.
  1. Mar 25, 2012 at 9:00 PM
    boostedka
    boostedka [OP] Well-Known Member
    James
    NM
    2000 2.7 4x4
    Custom Intercooled Turbo, Icon CO's, TC UCA, Icon 3 Leaf AAL, Rear 5100's, ATX Mojave 15x8, 33x12.50 STT Pro's, Nitro 4.88's, Pioneer & JBL stereo, Weathertech Liners, Wet Okole Seat Covers
    I just finished up my install of a TRD s/c on my '02 3.4 tacoma. I also installed with it the URD 2.2 pulley and 7th injector kit. I've noticed that is only maxing out at 5-5.5 lbs of boost. With the URD set up I was expecting around 9 lbs. Not sure exactly what's causing this. It definately feels somewhat sluggish for being charged. It doesn't feel as fast as it should. Also, The S/C is a used, rebuilt 2nd gen.
    Can anyone help out with this? Any suggestions are welcome.
  2. Mar 26, 2012 at 7:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    I have a feeling that your belt is slipping.
  3. Mar 26, 2012 at 11:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check all the connections for leaks after the SC. Use soapy water, look for bubbles.
  4. Mar 26, 2012 at 8:31 PM
    boostedka
    James
    NM
    2000 2.7 4x4
    Thanks for the suggestions.
    Today, I checked for dust build up from belt slipping and didn't see any. I didn't think belt slipage would be an issue with the URD pulley and a brand new belt. Also, i double checked the throttle body gasket to insure it was installed correctly as well as the check valve.
    I replaced many the vac lines with brand new ones and don't seem to see any leaks. I'll try out the water trick tomorrow though.
    I tested the bypass valve actuator and it doesn't stay fully open when i disconnect the vac line, open it up, cover the vac connection and let the lever go. It closes about half way before catching. I'll probably call magnuson tomorrow to order a new actuator if I don't find any vac leaks.
  5. Mar 26, 2012 at 10:31 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Fountain, Colorado/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    it might not be the belt or the pulley, it could be ur tensioner pulley not putting enough tension on the belt causing it to slip
  6. Mar 26, 2012 at 10:46 PM
    amain
    amain Well-Known Member
    Brian
    Seattle, Washington
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    I thought you would only get 6lbs boost not 9. You might want to talk to Gadget at URD to see what you should expect.
  7. Mar 27, 2012 at 6:37 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    Good ideas. I'll try calling URD today and see what gadget has to say about the ecpected boost. Is there anyone on here that lives around 4800ft elevation that is charged that can tell how much boost they are producing?
    As far at the tensioner, it is a dynamic tensioner so i'm not really sure how I would be able to know if the tensioner is slipping. WOuld the belt do something that I could see visually when reving the motor from in the engine bay?
    Thanks for the help.
  8. Mar 27, 2012 at 6:52 AM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    How tight is your belt. You should be pretty darn taunt.
  9. Mar 27, 2012 at 8:13 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    From what i can remember, seems like i can push it in with my finger maybe about a 1/4" to 1/2".
  10. Mar 27, 2012 at 8:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    There was is a guy on customtacos.com that was having a similar low boost issue. He realized that he could get more tension by flipping around something with the tensioner bolt on the alternator, or something like that. His boost immediately went higher. A lot!
  11. Mar 27, 2012 at 8:31 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    I noticed that when i rev the engine in neutral from under the hood, the belt sort of "flaps" in the area that goes from the dynamic pulley up to the S/C pulley. NOt sure if this is normal. Could my pulley tensioner be losing strength being a used unit?
  12. Mar 27, 2012 at 8:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    It should be tight. Not flapping. There should be a way for you to flip a bolt or something, to be able to add more tension. That will solve it the flapping issue.
  13. Mar 27, 2012 at 8:46 AM
    PkTaco
    David
    Zanesville Ohio
    Needs to be tighter, Should move like an 1/8 inch or less.
  14. Mar 27, 2012 at 8:50 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    can this be accomlished by adjusting the alternator bracket or do I need to replace the tensioner?
  15. Mar 27, 2012 at 9:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Take a look see at the alternator tensioner, and see what you can find out.
  16. Mar 27, 2012 at 9:09 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    Sounds good. I'll mess with that today after work. Thanks for the helpful suggestions
  17. Mar 27, 2012 at 9:56 AM
    wrmathis
    parts and stuff
    i wasnt talkin bout the tensioner slipping. was talkin bout it not makin the belt tight enough causing the belt to slip, but anyways i think u figured out what i was talking about with what everyone else was sayin :thumbsup:
  18. Mar 27, 2012 at 11:42 AM
    boostedka
    James
    NM
    2000 2.7 4x4
    Thanks for clarifying. That makes sense.
    Also, I talked with Gadget at URD and he said that the altitude I'm at is probably causing a decrease in the amount of boost. I did some research to follow this up and found that theoretically I should probably see about a 2.5 lbs decrease in boost pressure due to being at ~5,000 ft. Could this be accounting for the full loss of boost or is there possibly something else at play in addition to the altitude?
  19. Mar 27, 2012 at 11:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Altitude will play a roll as well. You can only fix the tension though. O_O lol.
  20. Mar 27, 2012 at 12:36 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Leaks and altitude.
