Low Buck, Campsite Solutions
Discussion in 'Off-Roading & Trails' started by Dirty Pool, Jul 22, 2016.
  1. Oct 30, 2016 at 9:37 AM
    #101
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Or cut the bottom out of a 5 gallon bucket and mount a seat on top. They have one for a bucket that has bags so you can pack out your waste but I mostly see people throwing their bags in the campground trash cans...pretty grosse. But I do like the chair idea and a deep hole.
  2. Oct 30, 2016 at 10:42 AM
    #102
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    If you have the space in your rig and want/need to confine your fire (camp/cooking), an old tub out of a washing machine works great. It also has a uniform top edge for any kind of grill you might have or make. Symmetrical rocks aren't always easy to find and you can always make a screen top for it in case of sudden winds that can blow cinders into the brush.
  3. Oct 30, 2016 at 12:25 PM
    #103
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    That's what we use in the yard for a fire pit, works great! Cook steaks over it sometimes too.
  4. Nov 27, 2016 at 11:15 AM
    #104
    Dirty Pool
    Dirty Pool [OP] FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Cooking Dogs
    Save those old telescoping antennas. They make great "sticks" for cooking hot dogs or sausage or marinated Dove Brest. In most cases the ball on the end will unscrew. Not for marshmallows.
    If you want a more versatile rig go with wood. Metal gets hot an marshmallows melt off.
    When you saddle up to the campfire with this baby on your hip, men avoid eye contact, women hold their children close.
    "Excuse me while i whip this out"
  5. Dec 1, 2016 at 10:26 AM
    #105
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    dtaco06 likes this.
  6. Dec 1, 2016 at 5:30 PM
    #106
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Camp stoves are so cool! They're the type of thing I could end up collecting if I'm not careful! I especially like the antique ones, old brass stoves from Optimus or Primus.
    Jim Bob and Martin64 like this.
  7. Jan 29, 2017 at 10:47 AM
    #107
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Back to fire starter, for those that carry hand sanitizer, I've heard it works excellent for starting fires because of its high alcohol content.
  8. Jan 29, 2017 at 2:54 PM
    #108
    phx13
    Rob
    2015 DCSB TRD O/R
    Sanitizer works in a pinch, but I like using dryer lint.
    Martin64[QUOTED] likes this.
  9. Jan 29, 2017 at 3:00 PM
    #109
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I put dryer lint in cardboard egg containers, (the cavity for the egg) and fill with wax. Cut apart, and you have a dozen starters per egg container.
  10. Jan 29, 2017 at 3:09 PM
    #110
    DrFunker
    DrFunker Well-Known Member
    That is great!
    Researching your idea I found this too.
    Wood pellets instead of lint. Would be a great way to use up all of the pellet dust in the bottom of the bag too.
    surfnmoto2 likes this.
  11. Jan 29, 2017 at 5:18 PM
    #111
    phx13
    Rob
    2015 DCSB TRD O/R
    When I was in scouts as a kid, we used to make these newspaper rolls and coat them with wax with a wick tied around them. Worked well.
    DrFunker and blind cowboy like this.
  12. Jan 29, 2017 at 5:19 PM
    #112
    phx13
    Rob
    2015 DCSB TRD O/R
    I'm hesitant to use wax these days because I live in AZ and it melts in my truck, but def works great for waterproofing. Just carry the lint in a gallon sized ziplock bag.
    DrFunker, Martin64 and Daria like this.
  13. Feb 8, 2017 at 7:36 PM
    #113
    .45 JHP
    .45 JHP Doesn't even own a Tacoma
    37.3582115,-121.9281197
    2015 4Runner TRD Pro
    I must find those wood sticks...
  14. Feb 14, 2017 at 8:28 PM
    #114
    phx13
    Rob
    2015 DCSB TRD O/R
    Any wood dowel should do
  15. Sep 2, 2017 at 12:54 PM
    #115
    Dirty Pool
    99 XCAB V6 MT TRD
    One more.
    Save that old, nearly obsolete cordless drill for the trail, powered from the truck battery.
    Gut the cells out of a bad/dead battery pack and solder in a set of 12g clip leads, length to suit. Most of these tools will tolerate a wide range of voltages with proportionate performance. A nominal 9.6v tool (below) on a 12v automotive battery really zings.
    This is non invasive to the tool itself so it still functions with the regular battery packs. I had "re-celled" several other packs with higher capacity cells a few years ago. They are still good and I wanted to still be able to use them.
    These "older" tools can be had for low cost at flea markets and such. This particular brand/series had a drill, sawzall, angle grinder, flashlight and circular trim saw.
    LTacoman, rogerman, SIZZLE and 3 others like this.
  16. Sep 2, 2017 at 7:49 PM
    #116
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Cool iidea!
    I have one of those laying around. I might just try that out.
  17. Mar 12, 2019 at 10:29 AM
    #117
    Dirty Pool
    99 XCAB V6 MT TRD
    This is certain to set the photography world on end, just kidding.
    Cheapo 3" wood worker clamp with 1/4-20 stud and a cheapo 7$ Amazon camera "ball mount".
    Saves an old man from getting in and out of the truck so much and works on tables, branches, road signs etc.
    Durango95, POOLGUY, Jiveydude and 3 others like this.
  18. Mar 12, 2019 at 1:08 PM
    #118
    Dirty Pool
    99 XCAB V6 MT TRD
    Ha, just noticed the "crevasse tool" in the last pic above. Upper right, next to the come along. Used for sucking GOLD from stream bed crevasses.
    Made from a gimmicky car wash wand/soapy water dispenser.
    POOLGUY, Jiveydude and Jmad1997 like this.
  19. Mar 19, 2019 at 2:33 PM
    #119
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    Long Range Shit Launcher
  20. Mar 20, 2019 at 11:10 AM
    #120
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's much more sophisticated than what I've seen before. In the rock climbing world, it's known as a "big wall burrito".
    You have some ~6" PVC not unlike what you have pictured, but just with threaded cap on one side, sealed other side - none of this fancy RV black water valve stuff.
    You take a paper plate, dooky on that, then fold it in half and deposit it in the tube and close it up.
    Not the most glamorous thing in the world, but when you're 1300 feet and 3 days into an ascent of El Cap, when you gotta got, you gotta go...
