Low Buck, Campsite Solutions
Discussion in 'Off-Roading & Trails' started by Dirty Pool, Jul 22, 2016.
  1. Mar 20, 2019 at 12:17 PM
    #121
    Dirty Pool
    Dirty Pool [OP] FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The hose flushing connection was a requirement at the time for use at public RV dump stations.
  2. Mar 21, 2019 at 3:01 PM
    #122
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's smart. I never had to use one (I never did big walls), but some people I climbed with used them. They probably just dumped it out and buried it, or maybe used plastic bags to line the tube with.
    Did you throw some RV black tank chemicals in there?
  3. Mar 22, 2019 at 5:36 PM
    #123
    Dirty Pool
    99 XCAB V6 MT TRD
    I think I mentioned in the OP, we never actually used it. I made it up many moons ago just to be "in possession" of an "approved" waste containment system for travel in back country areas that had such requirements. It's a copy, not something I came up with. The river folks like them because they are compact and easily stowed in a Kayak or the like. I believe the RV bayonet fittings allow it to be secured to an "official" dump station receiver and flushed with minimum impact or chance of "fouling" the area.
    When traveling under a back country permit, many times there is a required "orientation". It's usually a five or ten minute talk to assure you are aware of local cautions and regulations. It's not common but an official can request to verify that you possess such a system.
    It would be a sad day to travel 50 miles past this sign.
    Then travel the 46 miles of washboard past this sign to the Ranger station for your permit, only to be denied.
    We have always subscribed to the "cat hole" procedure but in our twilight years opt for the comfort of the folding throne. Possessing this and WAGS satisfies any requirements. In real life the throne typically sits over a cat hole. One hole to another, so to speak.
  4. Mar 23, 2019 at 1:13 PM
    #124
    jbrandt
    Justin
    The RV dump stations I've ever used don't really have much of a "connection". Just a hole in the ground with a cap. So the connection like you had on the tube just connects to a hose, and the other one of the hose has a 90 degree fitting and rests in the hole (isn't "sealed" by any stretch of the imagination).
    When I (attempted) Mt whitney a couple years ago, our permits included wag bags, which is just a bag with basically kitty litter you poop in and put in another bag. I saw so many of those littered on the trail. Awesome. They take the time to poop in the bag, then just toss the bag.
  5. Jun 27, 2019 at 2:14 PM
    #125
    Dirty Pool
    99 XCAB V6 MT TRD
    One more.
    Those military surplus tool bags are great for containment of various gear such as "Compressor, Air" "Gear, Recovery" "Battery, Emergency" or "Gun, Hand" . The true surplus or mill spec bags are high quality and rugged with a stiff bottom. The India/China Knock offs not so much.
    They seem to fit well in odd spots, being "soft sided" they can be coerced into places a rigid container can't.
    Air compressor featuring the Super Mod 4 valve Binford 1200V.
    Emergency battery, side pouches hold AC and DC charging cords.
    Some recovery gear. I made a spool for the old wire rope (90' x 5/16") for use as an extension when synthetic went on the winch.
    Made from a short bit of 3" PVC and two closet or toilet flanges cut down to the appropriate diameter.
    Yes, it takes persistence to master the winding technique.
    Durango95, Jiveydude and bprout like this.
  6. Jul 9, 2019 at 3:33 PM
    #126
    jbrandt
    Justin
    Don't you mean the Binford 6100 air compressor?
    rob1208 likes this.
  7. Jul 9, 2019 at 3:36 PM
    #127
    jbrandt
    Justin
    that's freakin genius!
  8. Sep 24, 2020 at 9:31 AM
    #128
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Reviving an old thread, but didn’t see cotton balls soaked in petroleum jelly for fire starter.
    It’s waterproof, lights with just about any spark and a single cotton ball burns for about 5 minutes. I take a tub of Vaseline and heat it up in a pot of water until it all melts. Take your cotton balls and stuff them in the container of your choice. I use another empty Vaseline tub and then pour the liquid jelly back over the cotton balls. When you go to light one, pick out a cotton ball and pull it apart into two pieces. Stick those two pieces back together with the fine fibers sticking up and light the fine exposed fibers. I use a fire steel, but you could even use the flint in an empty lighter to get it going.
    My parents now use this technique for lighting their wood stove. They don’t even need kindling.
    SnowroxKT, m3bassman, POOLGUY and 2 others like this.
