Low charge voltage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arrow2013, Jul 30, 2025.
  1. Jul 30, 2025 at 8:01 AM
    Arrow2013
    Arrow2013 [OP] Well-Known Member
    My alternator died and was rebuilt but now the voltage won’t go above 13.5 and will drop to 12.9 if I have all the electrical on. Battery voltage sits around 12.3. I have had autozone bench test the alternator and it passed the test. Anyone else have this issue?
  2. Jul 30, 2025 at 10:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check for voltage drop between the alternatir and battery.
    Engine running with loads on set your meter to Volts DC, one lead to the main alternator stud the other to battery Positive post, should be less than 0.5V
    Also check from the alternator case to battery Negative post, should be less than 0.5V
    joba27n likes this.
