Low compression/gas in oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by jonathan2986, May 7, 2017.
  1. May 7, 2017 at 10:08 AM
    jonathan2986
    jonathan2986 [OP] Active Member
    3rz
    hello,
    I blew my engine ( 1998 3rz) and had to buy one from the junkyard, i changed the headgasket and cleaned it up. I put it back in and it wouldn't start, did a compression test and got
    cylinder 1 90psi
    cylinder 2 80psi
    cylinder 3 90psi
    cylinder 4 110
    and it smell like gaz is in the oil.
    is it my rings? or my HG ?
  2. May 7, 2017 at 10:30 AM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    Gas in oil and low compression has me thinking rings
  3. May 7, 2017 at 10:35 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Time for a full rebuild...
  4. May 7, 2017 at 10:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Rings.
    You got a junkyard junker. Hopefully they gave you a warranty!
    Next time do the compression testing before installing the motor and save some headaches.
    Wulf likes this.
  5. May 7, 2017 at 11:12 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Do a wet compression test. Sounds like rings though.
  6. May 7, 2017 at 11:22 AM
    jonathan2986
    3rz
    thanks for the answers, i'll check my options...
  7. May 7, 2017 at 11:26 AM
    jonathan2986
    3rz
    do i have to resurface the cylinder walls when changing my rings?
  8. May 7, 2017 at 11:41 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Thats the right way to do it.
    wilcam47 likes this.
  9. May 8, 2017 at 3:14 PM
    jonathan2986
    3rz
    What if my engine didn't start ? it should start even though it has low compression, could it be my valve adjustments? The head has been moved around.
