Low Coolant Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mackoma, Sep 13, 2013.
  1. Sep 13, 2013 at 6:10 PM
    Mackoma
    Mackoma [OP] Member
    Mack
    Indianapolis
    2012 2.7 Access cab 4x4 SR5 auto
    Hey all,
    I've got a 2012 Tacoma 2.7 that i've had for 14 months. Today while checking my oil, I noticed that my coolant level was an inch or more below the full line. I checked it first thing this morning while cold after it had set overnight. Just wandering if anyone has experienced this and looking for a bit of advice. I have noticed since it was new, there is always a little residue surrounding the hose that fits on the top of the reservoir, I clean it up periodically when im under the hood and it keeps coming back. I have considered putting a hose clamp or twisting a piece of wire around it. Any suggestions or ideas why the level is low? Is this common?
    Thanks, Mack
  2. Sep 13, 2013 at 7:12 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Add some coolant back in and you'll be fine. Just routine maintenance, my did the same thing.
  3. Sep 13, 2013 at 7:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Same thing happened to my 07. I twisted a piece of wire around it, and that stopped it from leaking there.
  4. Sep 13, 2013 at 7:22 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Krazie knows what to do
  5. Sep 13, 2013 at 7:23 PM
    Mackoma
    Mackoma [OP] Member
    Mack
    Indianapolis
    thanks guys. i'll do both tomorrow.
  6. Sep 13, 2013 at 7:24 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    He'll never live that mistake down. He could cure cancer and everyone would still kick his bag in for his fluid fuckup
    OP, if it's any consolation, I didn't know I was low on coolant until I heard gurgling from under my dash. Air bubbles were causing it, I finally figured it out, but originally I though I had water trapped in the trough under the wiper cowl.
  7. Sep 13, 2013 at 7:28 PM
    Spoonman
    Jamie
    Alberta
    Hehehe it's fun to bug him about it. He's a good dude
  8. Sep 13, 2013 at 8:10 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    x2
  9. Sep 13, 2013 at 9:32 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    It's probably about to blow a head gasket, sell it!
    Kiddin. If it's the first time you've had to add any it's just normal evaporation and a little from the hose leak. You can add coolant or just some water for such a small amount, distilled if you can or at least purified with no minerals; tho a couple ounces hardly matters anyway.
    Before trying to clamp the hose you should clean it and the nipple of any hardened residue or it'll probably keep seeping.
  10. Sep 15, 2013 at 8:08 PM
    joes06tacoma
    Joe
    Central Coast, CA
    That would be normal with a cold engine. When warmed up it should be close to the full line, maybe even higher.
    I have also experienced the small leak at the overflow hose. I ziptied mine. Minor leak though, takes a long time to cause a low level.
  11. Sep 16, 2013 at 1:29 PM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    As long as your reservoir level is between the low and high marks you are okay. If it makes you feel better you can add a little distilled water or already mixed 50/50 coolant to bring the level up to the high. Adding coolant would be better but some folks don't want to buy a whole gallon of Toyota special long life coolant so the next best thing is adding a little distilled water which will eventually evaporate within time and you will be back to the low mark again, eventually.
