Low Electrical Power/Flickering Dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dtodd87, Apr 27, 2025 at 3:57 AM.
  1. Apr 27, 2025 at 3:57 AM
    Dtodd87
    Dtodd87 [OP] Well-Known Member
    Dylan
    06 4.0L TRD OR
    Engine: 1GR-FE stock ARB Safari intake CSF Performace radiator Front Suspension: B8 6112 shocks B8 upper control arms Rear Suspension: B8 5160 shocks Deaver Expedition series 2 Leaf springs (stage 2)
    I’m stumped,
    I’m having some Electrical issues, basically the dash lights started flickering one day and extended turn over during startup to the point my truck wouldn’t start
    As far as troubleshooting, I’ve since replaced my battery, alternator, starter, ignition coils/spark plugs, fuses and looked for faulty wiring
    I did “upgrade” my alternator/starter with PA Performace but kept the OEM wiring. I’m not seeing any over/under charge issues with the battery or anything so I don’t see this being the issue
    My UG shows the alternator voltage to be running anywhere between 13.85 and 14
    The truck is running but I’m still having the flickering lights and turn over during start up, and hearing a ticking noise periodically while driving, it runs fine mechanically but I can’t seem to pin point the issue
    This almost feels like there is something wrong with the security feature but I’m not exactly sure how to trouble shoot that
    Truck is an 2006 4.0L
  2. Apr 27, 2025 at 5:00 AM
    545 Well-Known Member
    2015 Access Cab
    Security wise it would still turn over fine, just wouldn’t fire
    Sounds like a bad ground, I’d check and clean them all. Now is a good time to do a wiring upgrade too, you don’t really want to run an upgraded alternator on stock wiring
    Dtodd87[OP] and ridefreak like this.
  3. Apr 27, 2025 at 5:06 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Poor connection somewhere, start with the last electrical thing you worked on.
    Dtodd87[OP] likes this.
  4. Apr 27, 2025 at 5:20 AM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    to add, I do have to unlock my truck (reset the security) sometimes before it fires, this isn’t every time though
    I’ll comb the wiring again and see what I find, I have some 2/0 battery wires I plan to install I just haven’t gotten around to it
