Low end power
Discussion in 'Performance and Tuning' started by WhiteTailPaul, Apr 20, 2013.
  1. Apr 20, 2013 at 5:07 PM
    WhiteTailPaul
    WhiteTailPaul [OP] Member
    Paul
    Northern Wisconsin
    2011 Tacoma
    Lifted
    I am looking to get more low end power from 2011 Tacoma 2.7ltr , this trk is used in the woods a lot mostly for hunting so a loud exhaust is out. Have been using low range but that blows.Already removed secondary air filter(helped some)and installed K&N filter.Running 235/75R16 Wrangler MTRs on stock wheels,any suggestions?
  2. Apr 20, 2013 at 5:36 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Any reason why 4Lo blows? For offroading I would think this would be the best option. There are lots of little mods you can do but none of them are to give you the kind of low end power that 4Lo does except for maybe a super charger, but that gets tricky for you since I don't think TRD makes one for the 2.7L.
  3. Apr 20, 2013 at 5:38 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Either that or a regear.... That will get you low end for sure
  4. Apr 20, 2013 at 5:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Get a V6
  5. Apr 20, 2013 at 5:38 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    4 banger lacks low end power, just the nature of that engine... :notsure:
  6. Apr 20, 2013 at 5:40 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Oh... duh:facepalm: Don't know why I of all people spaced the re-gear. This will probably hands down be your best option, other than trading it in for a V6 that is.
    I went to 4.88's and is has a lot more low end power.
  7. Apr 20, 2013 at 8:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Re-gear. For added fun, URD makes a s/c. Probably not the best bet for a hunting vehicle, but it would sure make getting there fun. ;)
