low engine revs
Discussion in '1st Gen. Tacomas (1995-2004)' started by IrmoRabbidMoose, May 9, 2012.
  1. May 9, 2012 at 6:29 PM
    IrmoRabbidMoose
    IrmoRabbidMoose [OP] Well-Known Member
    Jay
    Irmo, SC
    2003 SR5 Debadged 4x4
    tool box, tint. (Soon to come... HID's, Mud Terrains.)
    Hey guys, I'm new to the forum but not new to Tacoma's. However, I just recently purchased an 04 Tacoma double cab prerunner with 95k on it and I notice that on a cold start the truck starts normally and has high revs. Then, after I've been driving it and it's back at operating temperatures and I try to crank it, it starts normally but has very low revs where it just starts at the normal 750-800 rpm level. Any thoughts? I've never had this on a yota and I've had the 3.4's in several Tacoma's with 180k+ miles and they never did this. I'm thinking maybe cold start injector? Any thoughts would be greatly appreciated!
  2. May 9, 2012 at 6:58 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Same thing happens on my trucks. I've read about it before, seemed to be normal. It's been on my truck for over 100k miles
  3. May 9, 2012 at 7:03 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Mine too-normal. I just give it a little nudge on the pedal and it comes up to normal right away. Seems to be sort of a benign starvation quirk
  4. May 9, 2012 at 8:00 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    clean idle air control on throttle body helped mine
  5. May 9, 2012 at 8:50 PM
    IrmoRabbidMoose
    Jay
    Irmo, SC
    When I start it, it always goes straight to idle speed. It's not bogging down like it's going to stall out which is good. I'm just curious as to why it's just not revving high like on a cold start. But if it's normal for the 3.4's then I'll live with it. But thanks, I'll definitely clean out the IACV.
  6. May 9, 2012 at 9:42 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    So it does or doesn't have a high idle when you cold start it?
    Either way, when you start it up when it is completely cold, it is supposed to have a high idle until it comes up to opperating temp. That high idle will slowly drop down the warmer it gets until it reaches its designated opperating temp and comes to a complete idle. The 750-800rpm idle that you state is what it should be at, at opperating temp. If the engine is already warmed up, say while you're running errands or something and you get back in it, it shouldn't have the high idle anymore because it's already warmed up. If what is described here is the case, then it's completely normal and what every car does.
  7. May 13, 2012 at 11:09 AM
    IrmoRabbidMoose
    Jay
    Irmo, SC
    Yeah, I completely understand and I'm not saying that it's got a high idle. When I start it cold it revs high and then as you said it has a high idle. Well, I mean that once it's at operating temperature and I start it back up, it doesn't rev as high as when I first started it cold. It just runs up to maybe 1k then goes to normal idle speed. I'm wondering if this is normal or abnormal. Sometimes it just starts up and doesn't even rev, it just cranks and immediately goes straight to standard operating speed.
  8. May 13, 2012 at 11:21 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    All cars idle high when cold. You truck's normal idle speed should be about 600-700 rpms. A cold start will be much higher and stay higher until the engine oil and tranny fluid (auto only) is at normal optemp.
    Again, this is normal and nothing to worry about.
  9. May 13, 2012 at 4:58 PM
    Ridgerunner
    Frank
    San Francisco
    that is a bit clearer to your point-heck yeah that is totally normal. Mine sometimes won't even do 1000rpms full temp-it'll only do 700. Aint it cool tho the miracles of modern engines that can self-rev.
  10. May 14, 2012 at 6:37 AM
    IrmoRabbidMoose
    Jay
    Irmo, SC
    Thanks for the help everyone, I'm just going to do a little cleaning out on the engine and clean out the injectors and hopefully I'll solve my problem.
  11. May 14, 2012 at 11:25 AM
    Ridgerunner
    Frank
    San Francisco
    you still think you have a "problem" after we all told ya it's ok??
  12. May 15, 2012 at 11:26 AM
    Monkee
    Monkee Member
    Jesus
    FORT LEAVENWORTH
    07 SR5 TACOMA off road package
    Yea I just changed my plug on my taco 07' now it idles at 600 rpms is that normal or do I have to change it. If any onw one know how to fix it with out going to a shop let me knoe plse thanks to all
