Low Fuel Indicator too late :(
Discussion in '3rd Gen. Tacomas (2016-2023)' started by triumph65, May 11, 2018.
  1. May 14, 2018 at 10:12 AM
    #41
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is it really that inconvenient to spend 6 minutes filling up before you think you’re going to run out of gas?
    Not shitting on anyone, genuinely curious how this mindset works. If you drive a lot, you’ll fill up a lot. Fill ups are quick. You can double your fuel capacity and fill up less often, but you’re still spending time at the pump - now, twice as long but half as often.
    I don’t get the shell game. It’s the same, at the end of the year.
    Hank Heel and hiPSI like this.
  2. May 14, 2018 at 10:14 AM
    #42
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Somethings not right with that logic. If I changed when the needle hits 3/4 I’d be changing every 2nd or 3rd day. If I chose 7/8ths it would be every 1-2 days. If I choose 1/2? Then it goes 7-10 days.
  3. May 14, 2018 at 1:12 PM
    #43
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Everyone always mentions the fuel pump running hot. Isn't the fuel pump on modern cars cooled by the fuel running through it and not around it? It's probably why you never hear of OEM fuel pumps failing much these days, or at least not due to heat. The BMW ones that failed in the newer cars for example were manufacturer defects.
  4. May 14, 2018 at 1:16 PM
    #44
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    My light comes on with 5 gallons left,?
  5. May 14, 2018 at 4:20 PM
    #45
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yeah, you're right. Guess the coffee didnt kick in yet.
  6. May 14, 2018 at 4:41 PM
    #46
    RushT
    North Texas
    No worries man! If we could always put 20 gallons in and an overflow tank caught the overage, we’d be golden. :)
    It’s always a balance between being conservative and doing it more often which adds up to more time spent.
    For a year I commuted in my FJ about 55-60 one way. I filled up every 2-2.5 trips. Averaged about 3 times a week. Because the drives were so long, I ended up filling up at about a quarter tank. I run my taco farther. 1/8th or when the idiot light comes in.
