Low Fuel Light & Fuel Tank Capacity
Discussion in '1st Gen. Tacomas (1995-2004)' started by Davie Boy, Jul 8, 2014.
  1. Jul 8, 2014 at 11:19 AM
    Davie Boy
    Davie Boy [OP] Member
    Valencia, CA
    '99 Tacoma SR5, 2.4
    Hello.
    I recently purchased a '99 Xtra Cab, 2.4 liter, SR5. I've been operating under the assumption that the low fuel light doesn't work because it hasn't come on in the 8 months I've owned it. Recently though, I'm wondering if I'm just not letting the tank get low enough. I usually fill it up when the needle hits "E" and the tank will usually take between 11 and 12 gallons. The truck didn't come with a manual, but everything I've read online states I should have another 3 or so gallons for a total of 15. Does this sound correct? If so, just how low does the needle need to go before the light comes on?
    Thanks in advance,
    Dave
  2. Jul 8, 2014 at 12:36 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab
    My 04 takes 18.5 in the tank. I do notice it needs to be really by the E for the light to turn on.
  3. Jul 8, 2014 at 12:37 PM
    04yota
    Angelo
    Central New Jersey
    04 ext cab
    Check fuel economy.gov they have the capacity of the tank and miles on a tank
  4. Jul 8, 2014 at 4:49 PM
    cmj
    cmj Well-Known Member
    Danville, CA
    98 4x4
    33 Duratracs, 881 coils, all pro leafs, sliders, relentless bumper, warn winch
    My 98 either doesn't have the light or it burned out. I have run out of gas before so it definitely got low enough that it would have come on.
  5. Jul 8, 2014 at 5:41 PM
    Davie Boy
    Valencia, CA
    '99 Tacoma SR5, 2.4
    I've been reading a bit more on the subject. It sounds like the light comes on when about 4 gallons or so are left in the tank. I'm always adding about 11 or 12 gallons... so if the tank holds 15, I may not be running it low enough for the light to come on. I guess I'll test it and see. :confused:
  6. Jul 8, 2014 at 6:07 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    When you start running low, bring an extra gallon of gas to get you to the station.
  7. Jul 9, 2014 at 7:48 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Think 2wd has 15 gallon capacity while 4wd has 18 gallon. I have never seen
    a low fuel light on my 95.5 or my 96!
  8. Sep 18, 2014 at 7:54 AM
    stikle
    stikle Well-Known Member
    Seth
    Milwaukie, Orygun
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    I've been on E for a couple of days, just waiting for the fuel light...it hasn't come on yet.
    I went to get gas last night, and my normal station is closed for remodel. Oops. Oh well, I'll get to work and hit the one on the way home.
    20 feet from the parking garage entrance just after taking a corner, it died. I was able to start it again and get into the garage though.
    Gotta be on fumes if a corner sloshed the gas out of reach. Damnit. Now I don't dare try and make it to the gas station - I know it'll die on the bridge and I'll be blocking traffic, creating an embarrassment and hassle.
    At least I had the 5gal can in back that I was taking to refill too. Have to find a ride for fuel I guess.
    Happy birthday!
  9. Sep 18, 2014 at 9:14 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Just wanted to state that you should avoid running out of gas if possible as it may burn up your fuel pump. Gasoline lubricates the pump and when there is no gas/lube, things get hot in there and can cause the pump to seize. The fuel pump is inside the gas tank so its not super easy (or cheap) to replace.
    Look at the vehicle specs for tank size. If you want to confirm, I suggest only getting close to running out of gas. Figure out what your average MPG is and multiply that by the size of your tank, then travel that amount after filling your tank minus 1 gallons.
    E.g. If your avg mpg is 20mpg and specs say you have a 15gal tank, 15x20= 300 miles (Range) 300miles - 20miles(safety buffer) = 280 miles
    I have a 18gal tank (with about 18mpg) and my light comes on when theres about 3 gals left. That gives me about 54 miles before I run out of gas but of course ill be at a gas station within 36 miles. Plenty of time to get to my gas station of choice thats on my way
  10. Sep 18, 2014 at 9:59 AM
    stikle
    Seth
    Milwaukie, Orygun
    Well I certainly didn't do it intentionally. My plan was to go until the light came on, then fill up and see how many gallons it took.
    Absence of a light put a damper on that.
  11. Sep 18, 2014 at 10:02 AM
    bawilson21
    Bryan
    WA
    I was referring to this statement... Should've quoted sooner... :eek:
