Low Fuel light
Discussion in '1st Gen. Tacomas (1995-2004)' started by Get2dachopper, Jul 6, 2014.
  1. Jul 6, 2014 at 5:37 PM
    Get2dachopper
    Get2dachopper [OP] Member
    Orinda, CA
    2017 Magnetic Grey Tacoma Limited
    Maybe I have a bad case of OCD such that I always fill up my tank before reaching less than quarter empty but yesterday was the first time that I let my tank go nearly empty. The needle was right on the most lower part of the E hash mark....crazy I know right? Anyways In the many other cars I have been in the fuel light usually goes on stays on once the the tank reaches less than a 1/4 or 1/8 full. However, in my truck the light did come on but it would flash every 5 or 6 minutes. Is that normal? Wouldn't the light stay solid until the next fill up? I know this is an unusual question but I would appreciate some input.
  2. Jul 6, 2014 at 7:15 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Gas in the tank was probably shifting causing it to blink would be my guess. Bumpy or hilly roads?
  3. Jul 6, 2014 at 7:24 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Yep, what Pen said. Also, look around a bit, there's like 100 threads on the amount of gas left when the gas light goes on.
    *protip* It is 3 gallons. For both first and second gen. You weren't anywhere near as close to empty as you thought :) Check your owners' manual and you'll have it confirmed.
  4. Jul 6, 2014 at 7:29 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Just happened to me. I always thought my gas light was out but i was determined to find out if this was true. First it pulsed on and off every 3 mins on a flat road but when i got home after 4 miles it was constant on.
  5. Jul 6, 2014 at 7:33 PM
    jgillchevy
    jgillchevy Well-Known Member
    Dan
    Clarksville, TN
    2011 DCSB TRD Off Road
    5100s on all corners, front set at .85" w/ Eibach coils TSB rear springs w/ Wheelers offroad 3 leaf aal pack AFE drop in airfilter Weathertech floormats Wetokole seatcovers Tacoma bedmat Maglight install Rear diff breather mod Moroso oil catch can painted black rear bumper HomerTaco color matched satoshi grill BAMF bolt-on sliders URD fuel pump w/ external fuel filter Ultragauge
    mine comes on and stays on, no blinking, till I put gas in. I always have 4 gallons left in tank when light comes on.
  6. Jul 6, 2014 at 7:35 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Probably because yours is a 2011 and this is a first gen.
  7. Jul 6, 2014 at 7:46 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Pay attention to it, it'll glow somewhat even when it senses the fuel being a little low. The glow intensifies with the lower fuel amount. Sounds like you were on that "verge" of a fill up.
  8. Jul 6, 2014 at 7:49 PM
    jgillchevy
    Dan
    Clarksville, TN
    oh yeah, sorry, didn't catch that
  9. Jul 6, 2014 at 8:03 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I have had 2001, 2005 and 2010 Tacomas... and while my low fuel light didn't blink, if it had just come on at the end of a drive, it may not come on again, until a short time after driving it again.
    On my 2010, the light comes on when you still have 4 gallons remaining (down 17 gallons from full), +/- 0.5 gallon. The gauge needle will be on the E line with 3 gallons in the tank. At the half tank line, you are actually down just 9 gallons with 12 still in the tank.
  10. Jul 7, 2014 at 10:03 AM
    Get2dachopper
    Orinda, CA
    3 gallons even it's on the E hash mark line? Wow did not know that. Thanks for all the input. For a moment I thought something was wrong with the fuel gauge.
  11. Jul 7, 2014 at 6:37 PM
    David K
    Oh I find all sorts of ways to test my Tacoma!
    The E line is indeed a point of about 3 gallons still in the tank, but the needle keeps going BELOW the E line!!! Don't run out!
    Here is what I have in my truck tank (+/- 1/2 gallon):
    FULL TANK: 21 gallons
    F Line:...... 19 gallons
    3/4 Line:... 16 gallons
    1/2 Line:... 12 gallons
    1/4 Line:.... 8 gallons
    E Light:...... 4 gallons
    E Line:....... 3 gallons
  12. Jul 8, 2014 at 10:39 AM
    Get2dachopper
    Orinda, CA
    The owners manual says it has 15.8 gallons. Is the 21 gallon for the V6 model. I just have a 4 banger reg cab.
