Low fuel light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lowgybear, Jul 26, 2015.
  1. Jul 26, 2015 at 1:04 PM
    Lowgybear
    Lowgybear [OP] Member
    Ysai
    Tacoma TRD SPORT
    So this is my fist post here. I'm new to this so bear with me.
    First off my 2011 Tacoma has been sitting for most of the past 13 months.
    For the past few days that I've been driving it it's been all aces. Put about 20 bucks since I started driving it again. Today I ran out of gas... So I'm assuming.. The engine turns over but doesn't start. The steering wheel got hard to turn and the battery, oil and another few lights came up. Thing is that the low fuel light didn't even come up? Did I run out of gas or is this some kind of electrical problem? Maybe the starter?
  2. Jul 26, 2015 at 1:10 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Not trying to hi jack this thread but how low to you have to run fuel before the low fuel light comes on? So far mine has not come on but has not ran out of fuel either.
  3. Jul 26, 2015 at 1:17 PM
    Lowgybear
    Ysai
    Tacoma TRD SPORT
    No I didn't. Maybe that was my screw up? I'm also thinking the light didn't come on because the tank or fuel lines migjt have some build up in it?
  4. Jul 26, 2015 at 1:19 PM
    Lowgybear
    Ysai
    Tacoma TRD SPORT
    No worries holeshot... That's the exact problem I just had. My low fuel light didn't come on and I just ran out of gas.
  5. Jul 26, 2015 at 1:25 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Mine comes on when there is about 4 gallons left. Did this just to see when it came on.
  6. Jul 26, 2015 at 1:32 PM
    Lowgybear
    Ysai
    Tacoma TRD SPORT
    I'm going to put gas in it and throw some fuel system cleaner in it and see if it resolves the issue
  7. Jul 26, 2015 at 1:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My suggestion if you are going to put some gas in it, is to only put in at the most 5 gallons. You don't want to be messing with dropping that fuel tank fully filled if your fuel pump failed, which is a high possibility seeing that you ran the pump dry.
  8. Jul 26, 2015 at 2:46 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    Sounds like the battery is shot to me, your alt might even be bad.....
    *Edited because I'm a dummy
  9. Jul 26, 2015 at 2:55 PM
    Avsfreak18
    Robert
    2015 AC
    I stand corrected.... Dunno where my head's at today :bananadead:
  10. Jul 26, 2015 at 2:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Power steering is from a pump driven my the engine. If you run out of gas the engine stops and the pump stops and you have no power steering.
    There are vehicles with electronic power steering, but the Tacoma isn't one of those.
    How much gas does the gauge show? Full, Empty or what???
  11. Jul 26, 2015 at 2:57 PM
    Avsfreak18
    Robert
    2015 AC
    You are a merciful as you are wise *bows*
    KN[QUOTED] likes this.
  12. Jul 26, 2015 at 6:41 PM
    Holeshot
    Gary
    Alabama
    Apparently you are correct. A review of my Fuelly account shows the most fuel required for a fill up so far was 17.3 gallons so I had 3.8 gal. left
  13. Jul 27, 2015 at 4:20 AM
    Lowgybear
    Ysai
    Tacoma TRD SPORT
    The gauge was not reading empty.. It was about half a quarter till empty. Ok so I got some gas out in it turned on. I knew it was the gas! I emideatly went to auto zone and got some seafoam and dumped it in the gas tank. There must be a lot of build up in the tank from the truck sitting for so song. I'm going to wait a few more weeks and put another can of the stuff
