Low Gear / Range without 4wheel drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mark1285, Feb 20, 2017.
  1. Feb 20, 2017 at 12:39 PM
    mark1285
    mark1285 [OP] Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    No problem at all. I agree most people need lots of practice backing trailers. I just like the feel of low range power when crawling backwards. Although this idea seems like too much work for the advantage, I can just use 4 low if needed, its not so bad as long as i dont lock my front ARB by accident and snap a CV.
  2. Feb 20, 2017 at 1:27 PM
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    Putting on 2 inch bigger, heavier tires without regearing and pulling a 5k lbs trailer...that's a bit more strain on your drivetrain.
    I would either regear it or put the stock size tires back on.
    mark1285[OP] likes this.
  3. Feb 20, 2017 at 4:19 PM
    duckytw
    duckytw Well-Known Member
    Seems like an opportunity for toyota to make a real "tow" package with heavy duty clutch, upgraded rear axles, and allow for transfer case use without locking the hubs. Whats the multiplier on the rear with 4lo?
  4. Feb 20, 2017 at 4:40 PM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    This is one of the main things I miss about not having manual hubs. There are definitely situations where 2lo is helpful.
  5. Feb 21, 2017 at 5:35 AM
    mark1285
    Mark
    I plan to regear with 4.88's shortly. I agree I'll need the torque. In my opinion if you add anything bigger than a stock tire with this truck and plan to have any real function with hauling and loading the regear is almost a requirement. I think 2000 rpm in 6th is almost 100 MPH, with a high revving 6 cylinder that doesnt make a lot of sense. Derailed my own post though......
  6. Feb 21, 2017 at 12:07 PM
    tgear.shead
    tgear.shead Well-Known Member
    I blew the slip joint on my '91 YJ while in 4LOW.
    But that isn't really the reason why there is no 2LOW available, that is just your GUESS at why.
    In particular, this transfer case uses a single push-pull rod sticking out the end to control it through the FULL range of positions.
    All the way in one direction = 2HIGH.
    Next step = 4HIGH.
    All the way in other direction = 4LOW.
    Now if they wanted to, they could stick a neutral in between the 2 and 4 HIGH, but consider this;
    If you wanted a 2LOW position, how would you do it? Would you stick it between 4 HIGH AND LOW? If that is where you would put it, then how do you propose configuring the gears so that they go into 4H and then OUT of 4H at the next further position? Similar question would apply to every imaginable position.
    In other words, you CAN'T put a 2-low position into the transfer case without switching to a DUAL shift rod configuration. That means adding a second actuator, which adds to the cost.
    And frankly, it shouldn't be necessary. Rather than adding a 2LOW position, what would be REALLLLLLY nice, would be to add a couple of gears to the transmission -- 0, and R0, at something like 8:1 each.
    OP: Yes, you certainly can implement a wiring modification to trick the 4wd ECU into thinking that the ADD is engaged when it is disengaged (essentially 2LOW), and it shouldn't be ANY different than how it works for 2005-2015 models. Contrary to other people's warnings, CANBUS has nothing to do with it, because the modification alters the signals between the ADD and the 4WD ECU. Even if they did add some kind of canbus connection to the 4WD ECU, which I honestly doubt, then this wouldn't impact it at all.
  7. Feb 21, 2017 at 12:42 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    And that's your opinion...
    Meanwhile, I have an original CJ2A with a twin stick Tcase. Even though it has two separate levers (One for engaging front wheels, and one for range) there is an interlock pin that will not allow low range without the front axle engaged. For original Jeeps and anything else that used the D18 twin stick, it absolutely was for the reason I am saying.
    I'm nearly certain that the Tacoma has a front axle disconnect, which is how the mod works right? Why did Toyota decide not to just do the same thing the mod does and leave it disconnected in order to provide 2LOW? It has nothing to do with the gates of a single stick shifter like on a CJ5 or TJ because its an electronic rotary knob. They have chosen to engage in the 2Hi->4Hi-->4LOW sequence. They could easily have the knob be 2LOW - PUSH - 2HI - 4HI - PUSH - 4LOW. You would rotate the opposite direction to engage 2LOW.
    For a mechanical limitation or otherwise, they have chosen to always engage the front axle. It most certainly could be to try an limit the torque feeding to the rear axle which increased ~2.5 times when in low (don't exactly know the Taco ratio)
    Regardless of the reason. If you understand the system and its limitations, you would be OK to modify. Its the ham fisted morons that just want to keep gassing when they should be letting off that will get in trouble.
  8. Feb 21, 2017 at 12:49 PM
    tgear.shead
    And this has what to do with Tacoma?
    Because they're trying to make it SIMPLE, not like a space shuttle control panel.
    I'm not talking about the knob. I'm talking about the TRANSMISSION.
  9. Feb 21, 2017 at 2:34 PM
    mark1285
    Mark
    So where is the best source to get all the electrical and signal information I'd need for the 3rd gen to actually try and do a 2-low mod on the truck? I saw the 2nd gen wiring diagram, I'm guessing that could have changed.
    From reading the 2-lo thread, it seems someone may have made a plug and play solution for this. Does anyone know anything about that?
    This seems like something I'll eventually get bored enough to try and work out.
  10. Feb 21, 2017 at 4:30 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Just get the 3rd gen FSM and you can compare wiring.
  11. Feb 21, 2017 at 7:34 PM
    mark1285
    Mark
    Do you have a good source for 3rd gen FSM? I just googled it and nothing definitive came up? Can i get directly from Toyota?
  12. Feb 21, 2017 at 7:37 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    You can buy the paper version from Toyota, not sure if they have the PDFs or not. Usually just wait a bit and someone usually posts one online
  13. Feb 21, 2017 at 7:38 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    They're expensive though. Another option is to buy a few day pass to techstream and you can get it through there too iirc
  14. Feb 21, 2017 at 7:42 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
