Low geared??
Discussion in 'Wheels & Tires' started by Steve E, Feb 28, 2013.
  1. Feb 28, 2013 at 12:22 PM
    Steve E
    Steve E [OP] Well-Known Member
    Southern Missouri
    2014 TRD Sport DCSB 4x4
    I know it's not a Tacoma but I was wondering what causes my 1981 Toyota Pickup to be so low geared, it seems to be wound pretty tight between 65 and 70 mph, is it the transmission, the rear end or a combination of both that that is responsible, I am running stock wheel and tires? It is from the era that has 85 mph max on the speedometer.
    Steve E............
  2. Feb 28, 2013 at 12:45 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 15 Mustang GTPP
    Too few to list. 10 4runner SR5 4x4- 09 Pre-Runner TRD-OR AC- 14 Prius Two- 08 xB 03 Tacoma 5spd TRD OR 4x4
    Door jamb sticker will give you a lot more info than us guessing but I would say the rear end rather than the transmission but could possibly be both. I assume manual?
  3. Feb 28, 2013 at 7:30 PM
    Steve E
    Southern Missouri
    I'll probably go by the stealership and see if they can tell me which is causing it to be low geared. Being an 81 I guess it's probably older than most of the Guys on the Forum. LOL. I'm at a little over 278 K now and still running strong.
    Steve E...............
  4. Mar 1, 2013 at 8:59 AM
    DriverSound
    SoCal
    We've had many toyota's come and go within the family but the ones we kept have made it to 200K+ will little to no issues. BTW, door jamb info can tell you what kind of tranny and axle gearing you have.
  5. Mar 1, 2013 at 9:04 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    The cause of low gearing is usually low gearing.
  6. Mar 2, 2013 at 9:57 PM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    81's still had a 4 spd manual right? So my guess would be a lack of an overdrive gear combined with relatively low axle gears and small tires, is why she is screaming on the hwy. Put some bigger tires on it!
  7. Mar 5, 2013 at 12:52 PM
    Steve E
    Southern Missouri
    It has a five speed and the tires are one size over stock (D-78-14 = 175-70-R14 I believe) 185-70-R14. I had the ratios that the 'Stealership' gave me but misplaced the paper so I will have to ask them again.
    Steve E........
  8. Mar 5, 2013 at 1:00 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I had a '77, '83 & '95 PreTaco all 4Banger 5Speeds except '77 was a 4Speed.
    I don't remember what size the '77 & '83 took but stock size on the '95 was 195/75/14.
    Check your door jamb sticker to know for sure what stock size is.
