Low idle after changing belt and battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 009NJF, Oct 4, 2010.
  1. Oct 4, 2010 at 11:55 AM
    009NJF
    009NJF [OP] Member
    kissimmee, Florida
    2005 Tacoma 4x4 TRD SR5
    K&N cold air intake
    Changed a squeeling belt then found out i had a dead battery, changed that too but now my truck idles low.
  2. Oct 4, 2010 at 12:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Whats "Low"? What RPM is it idling at, and what is the tempurature state of the engine?
  3. Oct 4, 2010 at 12:23 PM
    009NJF
    009NJF [OP] Member
    kissimmee, Florida
    K&N cold air intake
    It starts out at regular idle like around 850 rpm then in about 60 sec. it drops to around 500 rpm
  4. Oct 4, 2010 at 12:28 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    its cuz u reset ecm learned memory when u replaced battery. try clean MAF sensor with good quality electronics cleaner. u must drive around for a little bit for ecm to re-learn values and drive patterns. its no probs.
  5. Oct 4, 2010 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    550 is normal for a warmed up engine (1GR-FE)
  6. Oct 4, 2010 at 12:51 PM
    tacobo670
    Ray
    Las Vegas
    im just saying.... v6 1gr should idle around 750-800 . 550 seems to low even for 2tr 4-cyl. if my truck idles at 550, im checking it out to see wats going wrong.
  7. Oct 4, 2010 at 12:57 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    Mine idles at about 550 - 600 when warmed up and AC is not on.
  8. Oct 4, 2010 at 1:01 PM
    tacobo670
    Ray
    Las Vegas
    idk. its all about learned memory. maybe my truck is at high idle all the time cuz i drive so fast all the time n i keep high rpm's while driving cuz i drive so fast when i drive really fast lol
  9. Oct 4, 2010 at 1:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im just sayin.....550 is a normal idle for the 1Gr motor.
  10. Oct 4, 2010 at 1:18 PM
    009NJF
    009NJF [OP] Member
    kissimmee, Florida
    K&N cold air intake
    Thanks, will try the cleaner on sensor and throttle body.
  11. Oct 4, 2010 at 1:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Resetting the ECU has nothing to do with the idle. The idle speed is a fixed value on the ECU.
    OP.....What idle is it at?
  12. Oct 4, 2010 at 1:27 PM
    tacobo670
    Ray
    Las Vegas
    resetting ecu can changed learned value of MAF sensor readings. if value is reset and maf is dirty, airflow readings will not be correct for ecu. it will eventually relearn/calibrate itself to airflow from maf sensor readings ("idle up"). i deal with that prob everyday. doing recalls on tacos for pedal recall where we gotta reflash ecu. its a common problem. im just saying thats how the system works. from my experience.
  13. Oct 7, 2010 at 5:54 AM
    009NJF
    009NJF [OP] Member
    kissimmee, Florida
    K&N cold air intake
    Thanks to everyone for your input,I got the problem resolve so I'm trucking again. I used a cotton swab with a little bit of soap water and cleaned the MAF, it seems years of k&N filter oil fouled it. Drove around a bit and it's okay now. Thanks.
