Low idle and stalling
Discussion in 'Technical Chat' started by Gloudeman65, Jan 7, 2018.
  1. Jan 7, 2018 at 2:51 PM
    Gloudeman65
    Gloudeman65 [OP] Member
    2007 gray tacoma trd
    Stock (for now)
    I just wired up my light bar, went to start my truck and it idles super low and when I put it in gear it stalls. I even disconnected the light and it’s still doing it.
  2. Jan 7, 2018 at 3:16 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just where did you wire the light bar??
    Was your negative cable disconnected ??
    Not tight enough when reattached??
    Have you looked for open circuit protection ??
    Break out the Meter
    tcBob, scottalot, Doogz and 1 other person like this.
  3. Jan 7, 2018 at 3:18 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Seriously. Could be many things.
    Need more detail!
    scottalot likes this.
  4. Jan 7, 2018 at 3:31 PM
    Gloudeman65
    Stock (for now)
    So I have a wire running from the lightbar to switch which is positive and then another positive wire from the switch to the battery with a fuse in between and then a negative to ground.
    My negative wasn’t disconnected.
    It’s tight,and no I haven’t
  5. Jan 7, 2018 at 3:41 PM
    nDub
    Lead Free Gasoline
    Can you check the volts* on the battery while the light is on and the truck is idling?
    Might be battery or alternator.
