Low Idle and Transmission issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jrcm10, Oct 24, 2015.
  1. Dec 4, 2015 at 7:09 PM
    #121
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    I'm parked on level ground in my garage. Seems to do it after seeing in the cold for 6-8 hours.
  2. Dec 4, 2015 at 7:31 PM
    #122
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    Same issue here. I'm researching how to check it myself. I have trust issues when it comes to the stealership. Is the Torque Pro app a reliable source for ATF temp?
  3. Dec 5, 2015 at 4:44 AM
    #123
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Also, any more info on the paper clip and flat tip screwdriver? Was that a McGyver related joke?
  4. Dec 5, 2015 at 9:43 AM
    #124
    db1984
    db1984 Well-Known Member
    Derek
    Bend, OR
    2023 Tacoma DCLB Off-Road Premium 4X4 w/ Adv. Tech.
    Full front and rocker PPF, ceramic coating, driver/passenger window tint (20%)
    Same with mine. Level ground. I'll see if the extra half of a quart makes the difference! They must not check the levels at the dealership because the service advisor said it "must have been low from the factory."
  5. Dec 5, 2015 at 3:34 PM
    #125
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    I've been thinking. Even if the fluid level were .5 to 1 qt low that's only going to change the actual fluid level by about 1/4" to 1/2", maybe. Every trans I've opened up has the oil pick up as low in the pan as possible. On a cold truck, a lot of the fluid drains back into the pan, raising the level well over the pick-up point. I'm willing to bet that if you remove the over-fill bolt on a cold truck, it's gonna piss out a good amount of fluid (correct me if I'm wrong). Logically, it doesn't make sense. If I wait long enough after going into D to let my truck start to move, no lag. What say ye?
  6. Dec 5, 2015 at 3:40 PM
    #126
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    I believe it has to do with the amount of fluid in the torque converter or something.
  7. Dec 5, 2015 at 4:21 PM
    #127
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    I don't think the torque converter drains passed a certain point after shut down. It should be ready to go.
    Fluid gets pumped in from the oil pump which is supplied by the oil pan pick-up that is fully submerged in fluid.
  8. Dec 5, 2015 at 4:43 PM
    #128
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Fuggin automatics... manual ftw. Almost all of the major issues people have been posting up for the 3rd gen are directly related to the automatic transmission.
  9. Dec 5, 2015 at 6:15 PM
    #129
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    I've researched that same issue. Seemed to pinpoint it to low headlight fluid. Better check it out as it has been know to cause early onset alzihmers. I hope is not to late for you.
  10. Dec 5, 2015 at 6:17 PM
    #130
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Wait... where'd he go?
  11. Dec 5, 2015 at 9:44 PM
    #131
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
    When mine is parked on slight angle with front up I get the delay. When parked with front end down there is no delay.
    Also when I started it today I gave it a rev to 2000rpm for a second. Let it come back to idle then no delay.
    I think it might be low, I should head to the dealer to get it checked.
  12. Dec 5, 2015 at 11:18 PM
    #132
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Yeah, no kidding. But if the pressure sensors in the headlight bulbs are functioning ok, then the tires would be flat like flap cats. Keep your seat belts fastened!
  13. Dec 6, 2015 at 12:03 AM
    #133
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Make sure to lube the Johnson Rod Assembly correctly and on schedule
  14. Dec 6, 2015 at 2:29 PM
    #134
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Update: The repair manual mentions nothing about pinning (paper clip) the thermostat on the 3G. It appears that only applies to the Tundra w/tow package. From what I can tell it's almost identical to checking the level on the 2G. I deleted earlier info to avoid confusing people.
    Disclaimer: Work at your own risk. I'm not responsible for your actions. I'm just trying to help. Good luck.
  15. Dec 6, 2015 at 4:16 PM
    #135
    Toneloc
    Toneloc Well-Known Member
    Northwest PA
    2016 DCSB 4x4 TRD OR
    Cool, thanks for the info. What is TIS?
    I found a youtube on checking fluid on the sealed toyota transmissions yesterday. Does our pan have the plastic tube that sticks up? What temp are you supposed to check it at?
    Anyone know if the techstream software will give you the transmission temps? Or is this just for changing dealer only preferences..?
    Thanks.
    Techstream on Amazon:
    http://www.amazon.com/Generic-V8-10...id=1449447250&sr=8-1&keywords=toyota+software
  16. Dec 6, 2015 at 5:14 PM
    #136
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    I'm gonna check mine next weekend to personally see if it is low or not. If you want something done right.....
    Toneloc likes this.
  17. Dec 7, 2015 at 11:04 AM
    #137
    Toneloc
    Northwest PA
    So procedure is....push in that button, hold in place with paperclip, allow transmission to warm up to certain temperature, and unbolt check plug that has plastic straw sticking up into the pan....and see if any fluid leaks out. If a small trickle or drip comes out the level is good, if not, need to add.
    What temp does the transmission need to be at?
    Does the techstream software allow you to read that?
    If not, how do you get the transmission temp?
    Thanks.
    Tony
  18. Dec 7, 2015 at 1:50 PM
    #138
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    No. Paper clip thing is not applicable.
    See here.
    https://www.tacomaworld.com/index.php?threads/63851/
    How to Drain/Refill Automatic Transmission
    On the 3G, remove the jumper wire after its in temp check mode.
  19. Dec 7, 2015 at 5:58 PM
    #139
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    Its because we are all in to big a hurry. Slow down and smell the roses.
    Rambeaux likes this.
  20. Dec 9, 2015 at 9:10 AM
    #140
    strosk
    strosk Well-Known Member
    Joe
    PA
    2016 DCSB TRD Sport 4X4
    Are you still having issues? I don't really much lag shifting to drive or reverse, but its definitely not smooth. I do have the same issue with quick deceleration and clunking into gear. Overall, my only real complaint is the automatic transmission and would love to have it resolved by adding a little fluid!!
