Low idle help !! 2nd gen Tacoma
Discussion in 'Lighting' started by Duhunkachunk, Sep 23, 2020.
  1. Sep 23, 2020 at 4:42 PM
    Duhunkachunk
    Duhunkachunk [OP] Active Member
    2009 Tacoma Access base 2.7 2wd
    EDIT:
    Low idle is normal when reconnecting or swapping out a batterie, the computer needs to relearn the correct idle and driving patters
    2nd gen 5mt Tacoma base model I just added oem fog lights, had the battery disconnected for an hour or so and now when I’m in neutral or just stopped I idle around 400-500 rpms. I am over due for new spark plugs but it ran like a champ before. My research is pointing towards it’ll take a while to relearn the correct idle because the fog lights are stealing power ?? Or is it just because I had the battery disconnected for a while ? Thanks I’m advance for any answers. Will update post with the answer to this problem for future tacomaholics !
    ABA180 likes this.
  2. Sep 23, 2020 at 4:45 PM
    rocklobster2008
    rocklobster2008 Well-Known Member
    Jayson
    Fort Worth, TX
    2008 Red Tacoma TRD Off Road
    Brute Force Fab front bumper Dobinsons Snorkel 35" Nittos Bilstein 5100s ICON leaf springs RSI SmartCap Bed Replacement Diode Dynamics lighting Custom built morimoto headlights RCI full skid
    Most likely will run like this until all the monitors have run and performed their checks. I believe it's running in open loop until at least the o2 monitor has run and come back good. I wouldn't worry too much about it. But if you feel the need to do anything, replace those plugs and clean your throttle body. Should be fine overall though.
  3. Sep 23, 2020 at 4:46 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Part 2..the battery disconnected means your computer is going to re-learn. Even if you just did that to replace the battery it would happen.
  4. Sep 23, 2020 at 4:53 PM
    Duhunkachunk
    Thanks, just had to clarify what I read from other posts. Any idea how long it would take ? And if it’ll relearn it on an hour or so drive (work tomorrow) ? Can’t bear to let it sit and the drive way and idle that low until it relearns it lol
  5. Sep 23, 2020 at 5:28 PM
    ABA180
    East Bridgewater MA
    Yeah you should be fine in a day or so with that drive. I had mine unhooked last year replacing the battery and just drove it 10 minutes home after, but I don't recall it taking more than the next day after to refresh
  6. Sep 23, 2020 at 7:00 PM
    rocklobster2008
    Jayson
    Fort Worth, TX
    Evap monitors will take the longest to run on their own. They have a very specific drive cycle/pattern to get to run. O2 monitor has a pretty detailed one but yeah I would better a day or two of normal driving should do the trick.
