Low mile Taco, doesn’t shift right.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRuby17, Mar 21, 2020.
  1. Mar 21, 2020 at 6:19 PM
    TacoRuby17
    TacoRuby17 [OP] New Member
    Alex
    2017 Tacoma SR5 4X4 double cab
    Hey y’all. I just bought a 2017 SR5. 3.5 with 6 spd auto. I have had the tranny flashed by the dealer. But it still doesn’t shift right on hills and just regular driving. When cruising along, anywhere between 45-70 or so. It I can feel almost like a slight hitch. Almost like a very small slip. But I do find that for some reason, driving with the traction control off it doesn’t seem to fear hunt as much. Is this common? Is there a fix out there? I’ve had it to Toyota 3 times in 3 months...
  2. Mar 21, 2020 at 6:31 PM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    Very common. Is the TSB 62 done on it? Ask your dealer about it.
  3. Mar 21, 2020 at 6:33 PM
    Catfish21
    Stockton, Ca.
    I had this issue with mine as well, after the tsb, no issues. Then again I’m on 35’s now so i hunt for gears A lot before regearing. After 5.29 gearing i feel stock again.
    TacoRuby17[OP] likes this.
  4. Mar 21, 2020 at 6:48 PM
    TacoRuby17
    Alex
    I’m not sure what they did to it. They just told me there was a TSB and something about flashing it. I’ll have to look at the papers. It was great at first. But now back to the crap it was doing before. Other than that it runs great. And I’m still running stock everything right now except exhaust. I just bought brand new 245/75r16. Wish I would have waited. Now I want the next size up and a mild lift. I put some sumitomo encounter AT. ( highly recommend ).
  5. Mar 21, 2020 at 7:30 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Early ones had issues. Warming up was the worst, but once past it's not too bad. Are you just cruising and you feel like it's slipping? I always run trac off. Once you've had it flashed, there's not a whole lot you can do other than go through the learning phase again, but it's mainly about learning how to work with the transmission. ECT, when to use the "s" functions and throttle control
  6. Mar 21, 2020 at 9:53 PM
    Catfish21
    Stockton, Ca.
    I would suggest a pedal commander, possibly.
  7. Mar 21, 2020 at 11:54 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Pedal commander won’t do anything to “fix” the issue. It’ll make your throttle feel more responsive but it won’t do a thing for the trans. the true fix is OVtune. A secondary option is new gearing ratio (4.88 or 5.29)but that still doesn’t truly fix the issue but makes the issue a bit more tolerable.
  8. Mar 22, 2020 at 12:02 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Run it in Sport mode so it's not using the learning transmission any more.
