Low mileage engine from 2013, compatible what year and model?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sqa4life, Aug 8, 2016.
  1. Aug 8, 2016 at 6:45 PM
    sqa4life
    sqa4life [OP] Well-Known Member
    2017 SR5 4x4 DCLB MGM
    Hi all,
    We have a very low miles engine and transmission from a 2013 Tacoma 4x4 automatic SR5 V6 from a wrecked truck.
    What year and model of tacoma will this engine/tranny compatible with?
    We are thinking of buying a high mileage Tacoma and swap the engine and tranny.
    Thanks
  2. Aug 8, 2016 at 6:48 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Aug 8, 2016 at 7:04 PM
    sqa4life
  4. Aug 8, 2016 at 7:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not sure on that one, but I can't see why not
  5. Aug 8, 2016 at 7:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The transmission from a 4x4 will only work in a 4x4. The housing is different - 4wd versions have a flange to mount the transfer case vs. a tailshaft housing for the slip spline of the driveshaft on 2wd models.
    Lord Helmet and sqa4life[OP] like this.
  6. Aug 9, 2016 at 5:05 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks I knew someone would chime in that knew
  7. Aug 9, 2016 at 6:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    also to use on a pre 2012 you will have to use the exhaust manifolds off an 05-11 as the 2012+'s have the air injection pump, You might be able to make block off plates for the 2012+ exhaust manifolds though.
    But yes it should work, and idealy you would use a 2wd trans for a 2wd truck or 4x4 trans for a 4x4 truck.
    landphil likes this.
  8. Aug 9, 2016 at 8:48 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Could possibly have some issues with engine electronics - honestly, don't know for sure.
  9. Aug 10, 2016 at 8:33 AM
    sqa4life
  10. Aug 10, 2016 at 8:40 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    That truck has "never been beaten or taken off road" so that 173,xxx miles really isn't "high mileage" in my opinion. I don't know, do what you want obviously but I would be inclined to get more life out of that engine and then do the swap in a couple years down the line.
    sqa4life[QUOTED][OP] likes this.
