Low oil level
Discussion in '4 Cylinder' started by Bscovi18, Apr 4, 2023.
  1. Apr 4, 2023 at 4:52 PM
    Bscovi18
    Bscovi18 [OP] Member
    Brad
    1997 tacoma 2.7L 4cyl 3rz-FE
    My truck seems to be losing oil. I am unable to detect a leak of any sort so I assume I’m burning it somehow. I replaced the pcv valve about a month ago and that didn’t seem to work. The truck runs fine and there’s no dash warning light, despite losing about a quart of oil every month or 2. Anybody have any opinions on what my next step should be? Thanks guys
  2. Apr 4, 2023 at 5:05 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    if no leaks its more than likely blowby. leaking past the piston rings due to the piston rings lined up together basically making a hole for burning oil. just a guess
  3. Apr 4, 2023 at 5:06 PM
    rtilton12
    Robert
    Texas
    you can have the engine running and take the fill cap or the dipstick out and if you see smoke coming out, pistons-blowby
  4. Apr 4, 2023 at 7:11 PM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    A 26yr old engine I'm assuming ? Either way sounds like you need to get a scope / camera in thru the spark plug holes in the head to check for cylinder wear..or the oil rings are stuck on the piston or pistons..could be a combination of cylinder wear plus oil rings..unfortunately..a last ditch roll of the dice attempt to free up stuck oil rings is to pour a 50/50 mix of ATF transmission fluid with acetone in each cylinder thru the spark plug holes and let it sit for a day or two then turn over the engine to drain most of it out, the rest can be pumped out with a small hose..you may see 1 or 2 cylinders that are empty which would be a good indicator of bad rings.. then do a complete oil change..its a flip of a coin to try to do something or just feed it oil..if it's burning oil, you should know about it and see signs of it burning oil besides it getting low on oil..
    HondaGM likes this.
  5. Apr 4, 2023 at 7:14 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It still runs?
  6. Apr 4, 2023 at 7:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ziptie a nitrile glove around the oil fill neck and see how long it takes to make a balloon
    BassAckwards, Zerksees and HondaGM like this.
  7. Apr 5, 2023 at 8:57 AM
    Zerksees
    Zerksees Well-Known Member
    2017 Access Cab SR 2.7L M/T 4WD
    How many miles are on the engine?
    HondaGM likes this.
  8. Aug 11, 2023 at 3:01 PM
    Bscovi18
    Brad
    186,000 miles
  9. Aug 11, 2023 at 3:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    What does a 'month or two' equal in miles driven?
    And what kind of miles? City? Interstate? Hooning?
    When starting cold, is there a huff of blue at the tailpipe?
    What do your plugs look like?
  10. Aug 11, 2023 at 3:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A compression check would be easy enough.
    That is, if you have the gauges.
  11. Aug 14, 2023 at 3:32 PM
    Clearwater Bill
    Billy
    Largo Florida
