Low Oil light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteveS197, Jan 26, 2020.
  1. Jan 26, 2020 at 9:25 PM
    SteveS197
    SteveS197 [OP] Well-Known Member
    Please help. Any idea WTF happened. I parked my truck no problem. To day I went to drive to work and all this came on. 2016 DC OR SB. I’m afraid to drive it. The sucky thing is, It’s passed the 36 month mark.
  2. Jan 26, 2020 at 9:26 PM
    Bishop84
    Bishop84 Well-Known Member
    Check your oil, but don't run it with that light on. I'd tow it if I wasn't sure.
  3. Jan 26, 2020 at 9:28 PM
    SteveS197
    Yes. That was the first thing I checked. It’s clean and full
  4. Jan 26, 2020 at 9:29 PM
    Sphinx
    Sphinx Active Member
    West Virginia
    2021 Toyota Tacoma TRD Sport w/Tech AT
    Oil related will “probably” be powertrain coverage. 5yr/60k Mile.
    AKGSD, SandyTaco4x4, SC4333 and 9 others like this.
  5. Jan 26, 2020 at 9:29 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If it's full, look up code setting criteria
  6. Jan 26, 2020 at 9:36 PM
    desert.taco
    desert.taco Well-Known Member
    Were you parked on an incline? That happened to me once while off roading. I was on an incline and turned the engine off and when I started it back up I got the warning light. Checked the oil and it was full. After driving for a few mins it went away.
    IEsurfer and shakerhood like this.
  7. Jan 26, 2020 at 9:47 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Bet your battery’s pooched. Double check your oil though before restart.
    edit: nvm saw its running. CPS hopefully..
  8. Jan 27, 2020 at 12:37 AM
    SteveS197
    The truck was parked and on flat level street. The oil is full and clean. What’s throwing me off is that the TRAC light is on, and it cannot be turned off.
  9. Jan 27, 2020 at 1:49 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sometimes the Trac light comes on with the CEL
    Superdave1.0 likes this.
  10. Jan 27, 2020 at 3:10 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    isnt the engine covered under the 60,000 powertrain warrenty ?
    Chew likes this.
  11. Jan 27, 2020 at 3:51 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    First guess oil pump or pressure sensor
    Superdave1.0 and uploadadventure like this.
  12. Jan 27, 2020 at 3:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Its not a low oil light. Its an oil pressure light. Significantly different.
    As others have suggested, pull the codes that are set first, and don't drive it just yet.
    Hoping something simple.
  13. Jan 27, 2020 at 4:21 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Oil pressure sansor could be clogged or faulty. Not sure its location on our v6... but they are typically on the topside on either the rear, or front of the engine I know 2nd gens had them right next to the oil filter.
  14. Jan 27, 2020 at 4:22 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I've never seen an idiot light for oil that wasn't tripped by low oil pressure. Also have never seen any automotive oil system with a method to show physical oil level.
    Some sensor is jacked most likely. Your truck might be one of engines with the bad CPS?
  15. Jan 27, 2020 at 4:39 AM
    SteveS197
    I don’t want to sound ignorant, but what is a CPS? Crank position sensor
  16. Jan 27, 2020 at 4:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Bingo! Tow her in.
  17. Jan 27, 2020 at 4:50 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Should be covered under drive-train warranty and if oil is full most likely just a faulty oil pressure sending unit or something related to it.
    SteveS197[OP] likes this.
  18. Jan 27, 2020 at 5:08 AM
    ryan760
    ryan760 Well-Known Member
    Child protective services light, it notifies authorities when you've been abusing your truck :p
    (yes crank position sensor)
  19. Jan 27, 2020 at 5:31 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    Correct me if I'm wrong, but why would a bad CPS cause a low oil light? CPS would cause starting/stumbling, valve timing issues/hesitation. not to mention a CPS specific CEL code to be set. more than likely, you may have a critter eating your wiring harness.. gotta love that SOY based wire insulation...
  20. Jan 27, 2020 at 5:37 AM
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    Most German cars have low oil lights.
    MR E30 likes this.
