Low Oil light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteveS197, Jan 26, 2020.
  1. Jan 27, 2020 at 6:13 AM
    SteveS197
    SteveS197 [OP] Well-Known Member
    Thank you everyone. The Mechanic just towed it to the shop. I hope it’s just a sensor.
    Taco_Craig, shakerhood and specter208 like this.
  2. Jan 27, 2020 at 6:43 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    The CPS signal wouldn't directly effect the low oil light, but for whatever reason the trucks with bad CPS were getting low oil light warnings and trans over temp warnings and other non related warnings. The one thing that was universal though was...never any code showing a bad CPS. Early victims had their trucks down for days/weeks because the techs couldn't find the problem and several reported that they informed the dealer/tech of the CPS issue only to be blown off.
    Critter chewed wires is entirely possible. Yeah Soy based insulation is beyond stupid, but blame the wire manufacturers, no auto mfg wants it. Clogged oil pickup not likely on low mileage engine running synthetic 0w-20
    shakerhood and SteveS197[OP] like this.
  3. Jan 27, 2020 at 7:31 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My old 5.0 explorer would warn you of low oil level or pressure. I saw it for the first time at 200K miles. The display would say low oil level and crawling under the car you could see the sensor in the pan. Think it's pretty common.
    Most newer German cars don't even have dispsticks for the oil. The computer tells you the oil level and you add/remove it based on what it says.
    https://blog.bavauto.com/15421/oil-change-on-bmw-without-dipstick-how-to/
  4. Jan 27, 2020 at 7:41 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    newer BMW, MERCEDES, have an electronic level monitor, but the engine has to be to operating temp, some AUDI's have a dipstick tube, but no dipstick my old shop we used one from an older VW PAssat I think. love oil changes in a MERCEDES.. have to suck the oil through the dipstick tube, land rovers were funny, the oil fill cap has a tube that runs down into the oil pan to suck up the oil using a vacuum machine.
  5. Jan 27, 2020 at 12:38 PM
    Banker
    Banker Well-Known Member
    OHio
    2017 Sport TRD DCSB
    @SteveS197 Keep up posted on what you find out. Thanks
  6. Jan 27, 2020 at 12:44 PM
    Duezzer
    Duezzer Well-Known Member
    Glenn
    2019 Cavalry Blue TRD Sport
    Some - Will list later - has lift and new wheels and rubber
  7. Jan 27, 2020 at 12:46 PM
    Duezzer
    Glenn
    My 1999 Porsche Boxster had an Oil LEVEL indicator. Just like a gas gauge. When you turned the ignition to accessory it would give you a bar chart. 1 bar from the top was about 1/3 a liter
  8. Jan 27, 2020 at 12:47 PM
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    What he said, @SteveS197!
  9. Jan 27, 2020 at 1:26 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    My wife's BMW doesn't even have a dipstick, only way to check the oil level is through the computer. Gives you a little bar display but the bad part is the engine needs to be fully warmed and it takes about 60 seconds while running. Some good that will do you if you are a couple quarts low...
  10. Jan 27, 2020 at 2:29 PM
    SteveS197
    The mechanic said it’s the oil filter housing. He’s picking up the part from Toyota in the morning. I’ll speak to him tomorrow morning on my way home from work, but Isn’t that covered under the warranty?
  11. Jan 27, 2020 at 2:30 PM
    Duezzer
    Glenn
    No Crap Eh!!!! At least Porsche it had a stick and the car needed to be off for a couple minutes.
  12. Jan 27, 2020 at 2:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Be sure to get a full explanation on how the filter housing set off a low pressure light. And how he was able to diagnosis that.
    whatstcp and tcjacado like this.
  13. Jan 27, 2020 at 2:45 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Who did the last oil change and when was it done
  14. Jan 27, 2020 at 2:45 PM
    nat103
    KY
    2017 DCSB OR
    My guess is leaking oil and the level dropped to low enough to drop the pressure. Hopefully I’m wrong
  15. Jan 27, 2020 at 2:51 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    whatstcp and nat103[QUOTED] like this.
  16. Jan 27, 2020 at 2:58 PM
    #36
    nat103
    KY
    2017 DCSB OR
    Checked right after he shut it off?
    or let sit to get an accurate reading
  17. Jan 27, 2020 at 3:32 PM
    #37
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If you don't have a Toyota service doing the work, you're on your own.
  18. Jan 27, 2020 at 6:14 PM
    #38
    SteveS197
    I guess Toyota will work on my truck for now on. Sucks that my Toyota dealer is a bit far from me. Thank you guys for all your help.
  19. Jan 27, 2020 at 6:21 PM
    #39
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    New Supra doesn't have a dip stick either. It does have a BMW engine, so that's what ya get.
  20. Jan 27, 2020 at 6:37 PM
    #40
    SteveS197
    I was just thinking. After this fix, should I bring it to Toyota for them to check his work, making sure it was done properly. I drive my Truck cross country regularly. Or maybe have them do a service on it and see if they say anything about it.
