Low Oil Pressure Alert
Discussion in '3rd Gen. Tacomas (2016-2023)' started by riplipper, Sep 18, 2019.
  1. Sep 18, 2019 at 8:45 PM
    riplipper
    riplipper [OP] Well-Known Member
    hey team,
    2019 Tacoma with about 4,000 miles on her. Started up my truck after work today and oil pressure alert came up. Shut the truck down, waited a couple minutes, and started back up and light hasn’t been on since. Drove the store and back and no issues.
    I did switch the truck very quickly into drive after starting up truck when the light came on, but it doesn’t seem like this would cause that.
    Anyone have this issue before?
  2. Sep 18, 2019 at 8:48 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Obvious question, but did you check your oil after? If you see that alert again, I would take it in and have the oil pressure checked. You could (hopefully) just have a bad sensor.
  3. Sep 18, 2019 at 8:49 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I would guess since you shifted so quickly you didn’t give the oil a chance to run through your engine and bring pressure up. Wait until you hear it idle normally, then shift after starting it up from when it was cold.
    DAS Taco likes this.
  4. Sep 18, 2019 at 9:06 PM
    scifidelity
    scifidelity Well-Known Member
    uhhhh check the dipstick?! Look under the truck?!
    VirusCage, cabotsteward and DAS Taco like this.
  5. Sep 18, 2019 at 9:09 PM
    riplipper
    Sure did check the dipstick. Things look good under the hood, which makes me think i probably just jumped the and started up too fast. Got a little antsy post work haha.
    Scared the shit out of me seeing light and feeling it go cold like that
    DAS Taco and GreyBaldTaco like this.
  6. Sep 18, 2019 at 9:11 PM
    scifidelity
    keep an eye on the engine temp as well. I would be checking my dipstick and under my truck daily for a little while. did you get under it? everything look good with the drain plug and filter housing?
    Big tall dave likes this.
  7. Sep 18, 2019 at 9:26 PM
    riplipper
    Everything is looking pretty solid underneath. I’ll keep an eye out for a bit to make sure, good call
  8. Sep 19, 2019 at 6:41 AM
    19DCSBTRDORTaco
    19DCSBTRDORTaco New Member
    Austin
    2019 Cement Tacoma TRD OR
    Did you notice for sure that the truck was even still running? I'm wondering if you shifting into drive so fast just caused it to stall which would flip on the low oil pressure message without anything being wrong with the truck. I could see not noticing that the truck stalled in the panic of seeing low oil pressure.
  9. Sep 19, 2019 at 8:31 AM
    riplipper
    It initially turned on and then in conjunction with the alert seemed to go limp and shut down.
    Would stalling an automatic like that have any negative effects?
  10. Sep 19, 2019 at 11:22 AM
    19DCSBTRDORTaco
    Austin
    I don't think it would cause any issues. Definitely better than if it had actually been running with no oil pressure. Kind of weird that it did stall though, but in the future, I would just give it a couple of seconds after its running before throwing it in gear and you shouldn't have any more issues. At this point I would say there's nothing wrong with your truck - you just caught it at exactly the wrong time.
  11. Sep 19, 2019 at 4:53 PM
    riplipper
    Excellent. Thanks for the tips everyone! Going to be keeping an eye out but if nothing is wrong I'll prob just wait until the 5k checkup to bring up to the dealership.
    specter208 likes this.
  12. Jul 23, 2020 at 2:00 PM
    TomDom
    TomDom Member
    Tom
    any update on this? Just happened to me.
  13. Jul 23, 2020 at 2:04 PM
    tcjacado
    tcjacado Well-Known Member
    Check the timing cover and all of the above mentioned items.
    If you have and all looks good, run with it. Better than going in to the, "sorry, we couldn't duplicate it the problem" from toyota.
    Get video of the light on if it returns for proof the truck is acting wacky.
    Skydvrr likes this.
  14. Jul 23, 2020 at 2:10 PM
    TomDom
    TomDom Member
    Tom
    I am going to pick up my truck from Toyota and they just told me "sorry, we couldn't duplicate the problem"
    What should I have them do?
    tcjacado[QUOTED] likes this.
  15. Jul 23, 2020 at 2:11 PM
    tcjacado
    Not much you can do.
    Accept delivery of your truck and wait until next time or don't and open a case with corporate.
    shakerhood likes this.
  16. Jul 23, 2020 at 2:12 PM
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    Dumb question.... Was she leaning to the right? Ive noticed on trails when the truck is leaning right.. light comes on every now and then.... they arent dry sump'd so it totally makes sense...
  17. Jul 23, 2020 at 2:12 PM
    TomDom
    TomDom Member
    Tom
    I truly appreciate your response. I was thinking about calling Corporate now and seeing what they think. Do you have any idea on what department I could call? It's so sad because it only has 23k miles
  18. Jul 23, 2020 at 2:13 PM
    tcjacado
    Its just the 1800 toyota care number I believe.
  19. Jul 23, 2020 at 2:13 PM
    TomDom
    TomDom Member
    Tom
    Not a dumb question at all! My driveway is a very slight incline (Nothing super noticeable) I only brought it up because I've seen a couple people mention it haha.
  20. Jul 23, 2020 at 2:15 PM
    TomDom
    TomDom Member
    Tom
    What's interesting too is I brought it in for an oil change the next week and a couple days later on a really hot day my gf started up my truck and saw the "a/t fluid overheating" alert came on and then went away.
