Low Oil Pressure and AT Low Oil at the same time
Discussion in 'Technical Chat' started by JaseVernon, Jan 25, 2015.
  1. Jan 25, 2015 at 8:23 PM
    JaseVernon
    JaseVernon [OP] Active Member
    Vernon BC Canada
    SR5
    Hi there, I am new to Tacos and new to the forum. I just bought a 2005 a few weeks ago and was driving home tonight from a longer trip and was 3 hours into the trip through mountains and both lights came on and it seemed like a light knocking, although I pull to the side, shifted into neutral and shut off immediately so I can't really gauge the knock.
    I had it towed and I am now in a hotel room searching for answers ( I have read through a tone, but none seem to fit) or at least some direction to a small town shop as they are the only one within hundreds of miles. ( so I am in control of what they do )
    As a background,
    - The truck just had the frame replaced (4 weeks ago) through the recall and during that time Toyota said they went through it thoroughly and only found catalytic converter issues
    - I noticed a bit of a "hot" smell when I stopped to get fuel but it was gone quickly
    - I have checked the oil regularly the last couple weeks and when I pulled over I checked it and it was still good after the issue
    - All regular services have been done since new
    1. What are the risks of starting it up to test oil pressure? Is there a way to make sure we don't do more damage?
    2. Any thoughts on why both lights would come on at the same time?
    thanks! Any help would be great!
  2. Jan 25, 2015 at 9:24 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    You didn't give miles on truck?
    but anyhoo, given what you said as to both lights coming on at the same time and recent service (frame replace) my first guess would be that it is electrical as in the plugs weren't pushed all the way together and came unplugged.
    Just my guess as to what is going on, but that's where I would tell them to start looking.
  3. Jan 25, 2015 at 9:32 PM
    JaseVernon
    Vernon BC Canada
    SR5
    Thanks and sorry, 250,000km(155000 miles).
    Would that cause the knock as well? It wasn't super loud. My worry is starting it to hear the knock.
    Thanks
  4. Jan 25, 2015 at 10:28 PM
    JaseVernon
    Vernon BC Canada
    SR5
    Also, anyway you can tell me what plugs? Is this easy to check? In the mean time I will search to see what I can find on these.
    Thanks again :)
  5. Jan 26, 2015 at 2:45 PM
    JaseVernon
    Vernon BC Canada
    SR5
    Ok here are the codes it is throwing...the dealer says bring it in of course. before I spend a ton of money to ship it from where I am stranded...any help?
    P0158 - o2 sensor high voltage (we knew this one was there)
    P0345 - cam shift position sensor A circuit Bank 2
    P0347 - cam shift position sensor A circuit low input
    P0348 - cam shift position sensor A circuit high input
    P0606 - ECM/PCM processor
    Thanks!
  6. Jan 26, 2015 at 3:15 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    p0606 is a shorted out 02 sensor not a bad ecm. its on cause the p0158 code
  7. Jan 26, 2015 at 3:38 PM
    JaseVernon
    Vernon BC Canada
    SR5
    Hmmm Toyota Master Tech I spoke with and Google show it as ecm/PCM issue....any rational on why?
    Also the p0158 has been on for a bit. Any thoughts on the knock and the ECM/PCM can shaft relationship?
    Thanks
  8. Jan 26, 2015 at 3:39 PM
    JaseVernon
    Vernon BC Canada
    SR5
    Oh and not challenging, just don't know any better. :)
  9. Feb 2, 2015 at 11:30 AM
    JaseVernon
    Vernon BC Canada
    SR5
    So it looks like the engine was blown. They still are not sure why both lights came on, however they say its most likely because of the blown motor. lol So we will see, I have ordered a new motor and will hopefully pull this one apart and see what happened.
    Thanks everyone!
