low oil pressure light while on pretty good incline.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beezlebubtaco, Jul 11, 2022.
  1. Jul 11, 2022 at 2:30 PM
    beezlebubtaco
    beezlebubtaco [OP] Well-Known Member
    Sergio
    2018 Tacoma sport
    went mild off roading this weekend and while i was on a pretty steep incline "low oil pressure" light came on and a second or two after the engine stopped. i've read a couple forums and i cant seem to find an answer on how to fix this.
  2. Jul 11, 2022 at 2:37 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Define "pretty steep".
    When you shut the engine off, were you on level ground or still on the incline?
    Have you checked the engine to ensure that it's not in fact low(ish) on oil? If it was only right after you shut the engine off, I wouldn't be inclined to worry about it. Likely a combination of hot (thin, and lets face it, 0-20 is only slightly above sewing-machine oil to begin with...), a slightly low oil level, and the normal pressure drop as the engine winds down.
  3. Jul 11, 2022 at 2:58 PM
    05 4x4
    05 4x4 Well-Known Member
    There is tons of info on this, the oil is pooling in the back of your head as there is no return line that is back there. Also its going into your PCV valve so it will burn oil out of the exhaust. Google some more and youll find tons of threads on this.
    Thatbassguy and MalinoisDad like this.
  4. Jul 11, 2022 at 3:12 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Did you shut the engine off, or did it die?
    Junkhead likes this.
  5. Jul 11, 2022 at 3:31 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Could recall the low oil light blinking on my 2001 tundra if going down a steep hill then coming to an abrupt stop...slamming on the brakes. Engine never quit though.
    beezlebubtaco[OP] likes this.
  6. Jul 11, 2022 at 3:38 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    brand new oil and its full. I never shut it off it shut itself off almost immediately after that light came on.
  7. Jul 11, 2022 at 3:38 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    it died.
  8. Jul 11, 2022 at 3:40 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    I have and I am still coming up empty handed and have read a few threads on TW but I didn't seem to find a solution. Maybe i missed it if you could show me?
  9. Jul 11, 2022 at 3:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I had the low oil pressure light come on for about 5 seconds while on a steep incline. Engine did not die.
  10. Jul 11, 2022 at 3:44 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Apparently catch can prevents this.
  11. Jul 11, 2022 at 3:45 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    i was reading that too but i also read that it didnt as well haha
    cryptolime and Junkhead[QUOTED] like this.
  12. Jul 11, 2022 at 3:46 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Can you help clarify the situation? Was it…
    1. The light came on a second or two after the engine stopped on its own, or
    2. The light came on a second or two after you stopped the engine, or
    3. The light came on and a second or two later you stopped the engine, or
    4. The light came on and a second or two later the engine stopped on its own?
  13. Jul 11, 2022 at 3:47 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
  14. Jul 11, 2022 at 3:48 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    the low oil pressure light came on and a second or two later the engine stopped on its own. it died.
  15. Jul 11, 2022 at 3:52 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Did it fire back up just fine?
  16. Jul 11, 2022 at 4:00 PM
    beezlebubtaco
    Sergio
    2018 Tacoma sport
    yeah fired right back up and i was able to climb it but i definitely had to keep a certain speed or else if i let it stand still it would had stalled again.
