Low oil pressure warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brob92, Oct 15, 2015.
  1. Oct 21, 2015 at 5:52 AM
    #181
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Do they have an area of their site for complaints/issues like this?
    Ares32 likes this.
  2. Oct 21, 2015 at 6:02 AM
    #182
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Sure did, and never came back.....
  3. Oct 21, 2015 at 6:05 AM
    #183
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Maybe but, you might be better off calling.
  4. Oct 21, 2015 at 6:10 AM
    #184
    swimmer
    Tucson
    2016 TRDORAC4WD
    I am sure they burped them ahead of time. Seems like a minor issue since it doesn't repeat, so far. I am not dissuaded in the least and am picking up my truck Friday. If it becomes a real problem Toyota will address it.
  5. Oct 21, 2015 at 6:25 AM
    #185
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    No worries guys, since this is not safety issue, Toyota will take care of that problem just like they did take care of the head gasket issue on 2005 -2006 trucks :D
    Paging @foampile so he can tell you how much Toyota contributed to head gasket issue on his truck....
    Honestly if you get oil pressure warning light which comes on at like 4-6 psi. You probably running low pressure other times too. And a lot is regulated by oil pressure in this engine.
    So Either stay on flat ground, or get some other truck (there are only 1000 Tacoma trucks left of model 2015 in US last chance).
  6. Oct 21, 2015 at 6:32 AM
    #186
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    been offroading in 4runner a ton, 2013 tacoma a lot, and ford f150's of various vintages
    NONE ever had low oil pressure no matter how much I dangled them
    this possible 3rd gen issue needs to be sorted out
  7. Oct 21, 2015 at 8:38 AM
    #187
    swimmer
    Tucson
    2016 TRDORAC4WD
    Have you driven on any inclines significantly steeper than what you are parking on when you get the low oil pressure warning?
  8. Oct 21, 2015 at 9:39 AM
    #188
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    The oil pressure light comes on when there is almost no pressure. Idle oil pressure is very low, usually around 5 psi. Higher pressure comes with RPM which is needed for VVT control, lash adjusters, and chain tensioners. With all the coatings on the internals oil isnt as much of a issue as it once was.
  9. Oct 21, 2015 at 10:12 AM
    #189
    BlueT
    NorthEast
    I went back and check for 1GR is 4.3 psi as minimum. So yup you are probably right, 5 psi is where they expect to be at idle.
    I don't know about coating, but generally running with no oil pressure is not a good thing.
    BTW what kind of coatings ? and Where ?
  10. Oct 21, 2015 at 11:01 AM
    #190
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    yeah what coatings ?
    there is no magic new unobtainium in this motor. it is steel vs steel vs aluminum with lubricating oil on the parts that touch and slide.
    what coatings besides a molecule-thin layer of oil ?
  11. Oct 21, 2015 at 11:05 AM
    #191
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I don't think foampile will be back for a while lol.
    Plus his, "I'm going to drive on a busted head gasket a few miles because what's the worse that could happen," has a lot to do with his problems.
    Anyways, continue on.
  12. Oct 21, 2015 at 11:21 AM
    #192
    usadaytrader
    usadaytrader Well-Known Member
    Read they do have anti friction coatings on the 2016 2TRFE internals
  13. Oct 21, 2015 at 12:08 PM
    #193
    swimmer
    Tucson
    2016 TRDORAC4WD
    OP, do you have the tow package?
  14. Oct 21, 2015 at 1:40 PM
    #194
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
  15. Oct 21, 2015 at 1:55 PM
    #195
    swimmer
    Tucson
    2016 TRDORAC4WD
    This guy's problem seems repeatable and dealer verified so he actually may have some issue but he's gone quiet.
  16. Oct 21, 2015 at 1:57 PM
    #196
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Toyota snuffed him out.
    Desert_Taco and Doggman like this.
  17. Oct 21, 2015 at 2:14 PM
    #197
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    His airbag failed to deploy when they curb stomped him.
    In all seriousness though things are probably hung up on Toyota's end until they get the okay from corporate to break down the engine to figure out what's up.
  18. Oct 21, 2015 at 2:22 PM
    #198
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Well, I'm figuring by this point if they've contacted corperate they are waiting for any sort of answer. The first ones they get should be simple, but if those don't work a teardown isn't unlikely.
    So it depends how you define "a long way out." With one of our Fords at work it was literally 24 hours before they started tearing down the engine only to find out the oil filter had been inhaled by the engine lol. How they didn't notice that before dropping the pan and pulling the heads is anyone's guess.
  19. Oct 21, 2015 at 2:24 PM
    #199
    BlueT
    NorthEast
    Meh the right guy to figure out this problem was here (on the forum ) today... It will get solved now... :D
  20. Oct 21, 2015 at 2:27 PM
    #200
    swimmer
    Tucson
    2016 TRDORAC4WD
    Probably more likely to tear into the ECU.
