low oil Pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by allwaysbroken5, Jun 15, 2023.
  1. Jun 18, 2023 at 2:49 PM
    #41
    allwaysbroken5
    allwaysbroken5 [OP] Well-Known Member
    jerry
    2010 Tacoma 2.7 manual
    none
    does the oil pressure sending unit come before or after the oil filter in the system?
  2. Jun 18, 2023 at 3:11 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Don't quote me, but I'm pretty darn sure it is downstream of the filter.
  3. Jun 20, 2023 at 8:32 AM
    #43
    allwaysbroken5
    jerry
    none
    lots of metal shavings in the pan are these going to be from the top end from low oil pressure?
  4. Jun 20, 2023 at 8:36 AM
    #44
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Probably bearing material from the main and rod bearings, was the engine ran low on oil when the old pan had a hole in it?
  5. Jun 20, 2023 at 8:40 AM
    #45
    allwaysbroken5
    jerry
    none
    never ran it with a hole in the pan put a hole in it when i was pulling the trans
  6. Jun 20, 2023 at 9:28 AM
    #46
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    ^^^^^^^ yep..
  7. Jun 20, 2023 at 9:39 AM
    #47
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Not really. Idling engines need almost nothing. The spec on some older toyota motors was 3psi @ idle iirc
