Low power past integration relay
Discussion in '1st Gen. Tacomas (1995-2004)' started by Salem747, May 23, 2023.
  1. May 23, 2023 at 7:18 AM
    Salem747
    Salem747 [OP] Member
    Sean
    1999 Tacoma, BHW TDI, Super Duty Axles
    Lots
    Hi all,
    I have done a swap in my Tacoma and a lot of splicing etc but a problem I can’t figure out is that my circuits from the integration really all seem to be really low voltage. I haven’t done anything to the wiring after it, nor before (I think) but most things won’t work that are fed by it. Dome light, clock, etc. even the gauge backlight only half comes on.
    Any troubleshooting people have done in this area?
  2. May 23, 2023 at 7:29 AM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Have you checked the voltage on both sides of the relay (with a voltmeter)? If the voltage is lower on the load side of the relay, then I would suspect a worn/dirty contact in the relay. If voltage is equal, as in close to battery voltage, then I'd check the chassis ground(s)
    Bivouac likes this.
  3. May 23, 2023 at 8:04 AM
    Salem747
    Sean
    Lots
    Yeah that’s the weird thing, the voltage seems ok until I connect everything back up. Then things won’t work.
    I was thinking ground but I haven’t messed with any grounds.
  4. May 23, 2023 at 8:11 AM
    jjsinaz
    Jim
    Sun City West, AZ
    You could try removing the relay and jumping directly across it and see if things work then. If everything works, then it's the relay if not start looking for a bad ground. Typically, if you have a bad contact in the relay and you have no load connected (no current draw) you'll measure the same voltage on either side. It's when you start to draw current through it, if the contacts have a high resistance, then you will drop voltage. Does that make sense?
  5. May 23, 2023 at 8:42 AM
    Salem747
    Sean
    Lots
    I did get a new relay from a junkyard but it’s different than mine. I have the brown one with 2 connections the one I got was blue with 1.
  6. May 23, 2023 at 8:52 AM
    Salem747
    Sean
    Lots
    I was also wondering if it had a feed from the ECM (my ECM is now for a TDI) but I don’t see one in the wiring diagram.
    it’s kind of weird in the wiring diagram because that integration relay does a lot of things but not really looked at in detail in the wiring diagram. It’s in there but usually just a box and not a specific call out of it.
  7. May 23, 2023 at 9:00 AM
    jjsinaz
    Jim
    Sun City West, AZ
    Sorry, now that I understand what an Integration relay is, not sure I am going to be much help. When I think of a relay I think of it as a small current draw circuit controlling a large current draw circuit (like a starter relay). This integration relay looks like it does a lot more than that. I think this is beyond my level of knowledge.
  8. May 23, 2023 at 9:02 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    jjsinaz likes this.
  9. May 23, 2023 at 9:17 AM
    Salem747
    Sean
    Lots
    Yeah it’s really not a relay. It’s a small IC basically.
    wondering if anyone else has had trouble with them or if there are any specific TS steps for them.
  10. May 31, 2023 at 9:13 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I can get you a little more info. PM me.
